Crank shaft is +0.10 with 0.10 mains new. spins by hand ok and end end float done.
Big ends +0.10 with 0.10 new bearings. spins ok.
Now i have a fair amount of resistance when i spin the crank over and have to use a spanner in the crank end slot it will not move by hand, it also has a preasure resisance as i can hear the hissing sound .
Now if it is at tdc the crank will rock a little with no resisance it only when the pistons start to move in the boars.
Is this right????
I did gap the rings and they where ok
Edited by ukcooper, 26 July 2012 - 02:29 PM.
