Mini 1000 Stage One
4 replies to this topic
#1 greensilver mini
greensilver mini
  • 585 posts
  • Local Club: HAMOC
Posted 26 July 2012 - 02:30 PM
hi later in the year i will be puting a stage one on my mini 1000.
already have the rc40 center exhaust and a 2nd box.
will this be good set up?
freeflow manifold
k&n filter plastic casing or cone what will be better?
hif38 carb what needle will i need?
Stuart
#2 nick.evans93
nick.evans93
  • 32 posts
Posted 26 July 2012 - 03:01 PM
An rc40 exhaust and a freeflow manifold is a good exhaust setup. If your referring to using a K&N filter element in the standard box, I don't think there is much of a difference performance wise between that and a cone filter, but I believe the main difference between the two is the induction noise is louder using a cone filter (prefer the cone myself).
I don't know anything about the needle to use for a hif38 but I'm sure the answer is on this forum somewhere, try using the search function, you could probably find the answers you are looking for in less than 5 mins.
Hope this helps :-) .
#3 greensilver mini
greensilver mini
  • 585 posts
  • Local Club: HAMOC
Posted 26 July 2012 - 05:04 PM
ok thanks that did help but did search but i get all different needles has anyone got this set up? and what needle do you use?
Stuart
#4 nick.evans93
nick.evans93
  • 32 posts
Posted 26 July 2012 - 09:12 PM
http://www.theminifo..._+hif38 +needle
#5 irish.yobbo
irish.yobbo
  • 90 posts
Posted 27 July 2012 - 12:00 AM
I wouldn't bother getting a needle you think is right. Get the car rolling road tuned by mini specialists, and they can pick the right needle for you. Chances are you'll choose a needle and they'll just change to another one.
I believe the standard box with several holes drilled in the side and a K&N filter is the best performance-wise. A freeflow manifold is probably your best bet - I have a LCB manifold, and it sits too low and it's a pain to get in place, and for a 998 not worth the effort.
