A couple of months ago i bought an austin mini red hot from 1988.
i have just run into an issue, i noticed my indicators and horn werent working so i checked the fuse and it had burned out. not only that but the previous owner soldered copper around the outside of the fuse to bridge it because the fuse had already burned out on him. i went to the shop and the guy told me the fuze that was in it was a 30 amp fuze. i thought i'd get a box of 30 amp fuzes and see what happnes. i put the fuze in, turned the ignition and the fuze glowed red hot and melted. i noticed some bad wiring from an old radio that used to be in there so i took it all out but to no avail. i then proceeded to take out the dashboard unit and disconnect all the steering collumn swithches and buttons. leaving only the ingition connected. still the same problem. if i disconnect the green cable from the fuze leaving only white-fuze-purple it does'nt short.
I have tried finding a wiring diagram but no luck so far. does anyone know what the green cable connects to or why it could be shorting
here's a pic of the fuse and cables.
