Edited by cian, 29 July 2012 - 12:26 PM.
Tips On Removing Old Underseal
Posted 29 July 2012 - 12:25 PM
Posted 29 July 2012 - 12:50 PM
then you could gently heat it and wipe off the remaining
and then some degreaser should get the rest off.
Posted 29 July 2012 - 02:14 PM
My method requires that you invest in a disposable long-sleeve shirt, a face shield (like used for grinding) a hot-air gun, putty knives, and leather gloves. Working on your back, heat a spot with the hot air gun. As it starts to soften, use the putty knife to scrape it off. Get as much off as possible with heat and scraping. Then, use a ScotchBrite pad wet with mineral spirits, diesel, or kerosene and scrub the surface. Wipe the scrubbed surface off with disposable paper towels. Repeat as necessary until it is as clean as you want it.
Other ways involve freeze sprays and chipping hammers, impact tools for electric drill bits, and chemicals. In the end, heat and scraping has always worked best for me.
Posted 29 July 2012 - 02:28 PM
Posted 29 July 2012 - 03:38 PM
Posted 29 July 2012 - 04:17 PM
Posted 29 July 2012 - 05:31 PM
Everyone has their favorite method for taking care of this nasty task. Every method has some degree of risk. Regardless of the method you choose, use safety gear... particularly for your eyes and hands.
Posted 29 July 2012 - 05:36 PM
Posted 29 July 2012 - 05:53 PM
Posted 29 July 2012 - 06:59 PM
Posted 29 July 2012 - 08:33 PM
Posted 30 July 2012 - 07:17 AM
Posted 30 July 2012 - 07:58 AM
eBay item : 280716504213
With these i managed to rub all the old underseal off then I carried it on & removed the original primer. & re painted & wax oyled the lot
Posted 30 July 2012 - 12:36 PM
What is the procedure when using a heat gun to remove the underseal?
Heat the undercoating until it gets soft, scrape it off with a putty knife. Because the undercoating is very hot and sticky at that point, you MUST wear a long sleeve shirt and gloves. If working on your back, face protection (like a full face shield) is a very, very, good idea. That hot undercoating will stick to your skin and make a very deep burn.
