Piston Gap
Posted 29 July 2012 - 06:24 PM
Posted 29 July 2012 - 06:33 PM
The critical clearance is measured at the bottom skirt of the piston, this should have been done by the engine builder.
Posted 29 July 2012 - 07:16 PM
I am assuming your engine is a 1275cc as you say it's on standard pistons and rings?
The standard size bore for a 1275cc engine is 70.6mm so the bores seem a little on the large size.
Has the engine had a rebore and new pistons fitted? The first rebore is +0.020" which gives you 1293cc
This gives you a bore of 71.145mm, which appears to be what you have.
If its a newly machined block, the rings will need time to bed in and until this happens you should expect a bit of smoke and crankcase pressurisation.
Steve
Posted 30 July 2012 - 09:02 PM
Posted 30 July 2012 - 09:03 PM
Posted 30 July 2012 - 10:12 PM
It does sound as though your block has either had a +0.020" rebore or is worn ecessively making the standard sized pistons loose in the bores.
In order to get an engnie running without loss of compression (which you may have with loose fitting pistons) you must use pistons suitable to the bore size. A good engine machining shop will take your block and new pistons, or supply the pistons themselves, then bore the cylinders to suit.
Anything less than this is going to cause you problems!
What do your bores look like? Are there cross hatching lines in the bores or are they smooth with a defined lip at the top of the cylinder where the bores are worn.
The only smoke you should get on a newly built engine is maybe a little out the exhaust whilst the rings are bedding in and possibly a slight blue haze out of the oil filler cap hole until the rings seal properly.
Hope this helps!
Steve.
Posted 01 August 2012 - 09:18 PM
Posted 01 August 2012 - 09:53 PM
Just really need to get the bores measured accurately, so you know where you are. Try to keep rebore sizes to a minimum.
No point on going +0.060" if +0.040" will do the job. It certainly seems from what you've described as though your block has had a +0.020" rebore but has been fitted with standard size 1275 pistons!
Cheers, Steve
Posted 01 August 2012 - 11:27 PM
Posted 02 August 2012 - 06:53 AM
Posted 02 August 2012 - 11:49 AM
Posted 03 August 2012 - 05:58 PM
Posted 03 August 2012 - 05:59 PM
Posted 03 August 2012 - 06:52 PM
Still sounds like standard pistons in bores that have a +0.020" rebore, based on your measurements Paul.
It's probably best to strip it all out, get the bores measured accurately by a machine shop and go from there.
A measurement of 71.145mm on good condition, lip free bores with cross hatch patterning is a +0.020" rebore so you would need pistons to suit, then go from there!
Cheers, Steve
Posted 03 August 2012 - 07:05 PM
