Hazards Not Working!
Posted 30 July 2012 - 06:15 PM
Any ideas on what could be causing the hazards to stop working?
Its a 1991 Rover Mini Mayfair if that helps matters
Thanks in advance
Posted 30 July 2012 - 06:56 PM
If you only have one, pull your hazard switch forward of the switch panel and take a close up of the plug with wiring so i can see which colour codes you have and ill tell you which ones to test with a multimeter. :)
Posted 30 July 2012 - 07:15 PM
Just thought it was weird that this happened at the same time the fuse in the top slot of the fuse box blew but once that was replaced my hazards still don't work.
When I press my hazard switch nothing happens at all no light on the switch and no noise from the flasher unit if that helps.
Posted 30 July 2012 - 07:43 PM
Posted 30 July 2012 - 08:11 PM
Posted 30 July 2012 - 08:16 PM
Edited by TheBlueMeanie, 30 July 2012 - 08:16 PM.
Posted 30 July 2012 - 08:17 PM
Posted 30 July 2012 - 08:33 PM
Posted 30 July 2012 - 08:51 PM
Posted 01 August 2012 - 10:54 PM
The feed to the flasher is purple/orange and almost always shares a fuse with the interior light. Does that work? The fuse is fed from the brown (permanently live) circuit, and in the majority of cases is an in-line fuse, not in the box. The cause of the fuse blowing is very often a short to earth at the interior light, which happens either due to mechanical damage or by putting the wires on the wrong terminals.
Posted 02 August 2012 - 04:24 PM
Posted 02 August 2012 - 05:11 PM
If it is a single flasher for both functions, it would have to be the solid state type to keep the flash rate within the legal limits whether it was feeding two lamps or all four. A hazard flasher used for normal indicators will flash slowly, if at all. But there is a much more fundamental problem, the hazard flasher MUST be powered from the permanently live circuit as it must work at any time, with or without ignition key, but the indicators MUST be powered from the ignition switch controlled circuit, in the UK at least, therefore it would be impossible to use one flasher for both functions without complex extra switching. I would be very interested to know where you found the diagram which shows only one flasher, as the 20 or more Mini wiring diagrams which I have available all show two.
It is also rather fundamental that if you overstress any electrical component beyond its design limit, it may be damaged, and may fail prematurely, if not immediately. I happen to have 39 years experience in high reliability electronics design, and am fully conversant with how and why things fail.
Posted 02 August 2012 - 05:43 PM
Posted 02 August 2012 - 06:00 PM
Posted 02 August 2012 - 06:42 PM
