Hi,
I am running a 1330cc, with a stage 3 head, 1.5 hi-lift rockers, 286 kent cam, duplex timingchain and twin hs2's but the car was running on a manual fuel pump, but is now broken.
My question today is which fuel pump do i go for, a manual fuel pump again, road race facet fuel pump or a electric fuel pump?
If i go for any of the electric fuel pumps how are these fitted, as i have never played around with these. What other parts would i need for the electric fuel pump?
Any help is really appreciated.
Thank You
Bobby
Help On Fuel Pump
kappa
, Aug 01 2012 09:16 PM
3 replies to this topic
Posted 01 August 2012 - 09:16 PM
Posted 01 August 2012 - 09:52 PM
this type...........................
and I fitted it here......
Posted 02 August 2012 - 07:49 AM
what type of facet fuel pump is this?
Posted 02 August 2012 - 12:14 PM
That is the basic Facet "cube" pump. They have been around for years. When selecting one, be aware that they are available in different pressure ranges. You want a low-pressure one, one that delivers 3 PSI or less. If you choose one with over 3 PSI you need to fit a pressure regulator before the SU carbs to drop the pressure so it does not overpower the float valve in the carb.
http://www.facet-pur...l-pump-kits.php
and a catalog link below...
http://www.facet-pur... (Original).pdf
The cube pumps work well for years and are less expensive than their "gold-flow" interrupter pumps. (product flier link below)
http://www.facet-pur... flyer 2011.pdf
I have used both. Cubes are less expensive, gold-flow are more expensive, larger, but quieter.
