New Engine In And Found A Bonus
11 replies to this topic
#1 H.M.M.
H.M.M.
  • 332 posts
  • Local Club: Witney Invaders
Posted 01 August 2012 - 09:48 PM
Fitted my new engine finally, just got to put the rest of her back together.
It's a metro 998, took the head off as I'm fitting a 12g head on and found a set of flat tops. So I thought great, then I was going to change my cam shaft too, only to find a Kent 266 fitted. What a bonus.
The only thing is I know nothing of the piston, but they have the markings 21964 G8. Are they any good?
Attached File  IMAG1332.jpg   53.04K   30 downloads
Attached File  IMAG1321.jpg   75.02K   11 downloads
#2 MiniElliott
MiniElliott
  • 378 posts
Posted 04 August 2012 - 07:36 AM
That's a nice find. I wish my 998 had a surprise like that. The pistons will be fine for a fast 998 aslong as they are not damaged. What's your final drive ? Mine turned out to be a 3.6 which was nice for acceleration.
#3 1984mini25
1984mini25
  • 8,785 posts
Posted 04 August 2012 - 09:45 AM
I wouldn't get too excited, most a+ 998s have flat top pistons as standard.
#4 coopdog
coopdog
  • 4,506 posts
Posted 04 August 2012 - 10:04 AM
yeah pretty much all of them do, but the cam is a good one!!
#5 konyo
konyo
  • 1,107 posts
  • Local Club: Mini Freakz of Sussex
Posted 04 August 2012 - 11:41 AM
I got excited then! I was like omg mine has flat top pistons!!!! Ahhh! But then shattered as I read that post :(
#6 1984mini25
1984mini25
  • 8,785 posts
Posted 04 August 2012 - 11:59 AM
It's true tho, there's also nothing special about the metro 998s they are still the same A+ unit...
#7 H.M.M.
H.M.M.
  • 332 posts
Posted 04 August 2012 - 12:19 PM
So a standard A+ would have had these pistons off the line. No wonder they are better engines.
Well it will have a bit more poke than the 1098 that was in there previously.
#8 Chance
Chance
  • 1,457 posts
Posted 04 August 2012 - 02:02 PM
Youve got me thinking now
I have a 1985 998 mini.
The engine has flat top pistons and a ducellier dizzy which I heard were used in metros??
Is this my standard engine or has it been changed??
Well i guessworked my engine number, apparently its a mini A+. Final Drive is 3:105:1 is this any good ??
Sorry for the thread Hi-Jack >_<
Edited by Chance, 04 August 2012 - 02:29 PM.
#9 mk1leg
mk1leg
  • 9,343 posts
Posted 04 August 2012 - 02:36 PM
Your going too have to cut valve seat pockets in the block for a 12G940.....or you will bend them.......
#10 1984mini25
1984mini25
  • 8,785 posts
Posted 04 August 2012 - 03:02 PM
Nope it'll be standard, Austin rover went through a faze in the mid 80s of fitting the rubbish ducellier dizzys.
#11 Ethel
  • 26,029 posts
Posted 04 August 2012 - 03:18 PM
It's pot luck on the dizzies, they did have an assembly plant in Belgium, I'm not sure if all the Ducelliers were fitted there. There were 2 flavours of 998 A+, the standard one was low compression (dished pistons and a 3 into 1 exhaust manifold). The HLE version has the flat tops and a cast version of an LCB. The latter was used in City E Minis, without the exhaust manifold.
#12 Chance
Chance
  • 1,457 posts
Posted 04 August 2012 - 05:45 PM
Whats wrong with the ducellier??
Mines a Ritz, cant remember what they are based on.
