How To Lower Hydrolastic
6 replies to this topic
#1 Jack rabbit
Jack rabbit
  • 45 posts
Posted 02 August 2012 - 03:16 PM
I have a fully restored wolseley hornet mk3. I've put some white coopers s wheels and yoko ao32 on it as i am looking for a retro look.
I would like help on how to lower it I know I may need to put dampers on the front but other than that I'm not sure
Any ideas would be helpfull
Thanks jack
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 02 August 2012 - 03:54 PM
much the same as a dry suspension mini you need the distance between the spring and knuckle shorter
#3 mk1leg
mk1leg
  • 9,343 posts
Posted 02 August 2012 - 05:01 PM
let out some fluid..........LOL................ :proud:
#4 Jack rabbit
Jack rabbit
  • 45 posts
Posted 02 August 2012 - 08:39 PM
Lol I thought about letting fluid out I think that only lets the back down not sure I will look into it a bit more at the weekend
Cheers guys
#5 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,154 posts
  • Name: Sean
Posted 02 August 2012 - 08:45 PM
The valves are sided left and right.
Mine sits ok, this was done to the old elf workshop manual, can't remember the figures but I can dig them out.
#6 tiger99
tiger99
  • 8,584 posts
Posted 03 August 2012 - 09:36 AM
Do not let out fluid. As has been said, it can only be done properly by machining the struts. You will also need shorter pitch control springs at the back.
#7 mk1leg
mk1leg
  • 9,343 posts
Posted 03 August 2012 - 09:34 PM
Of cause you have to use a suspension pump.....or you will waste the fluid......LOL.....I lowered my old 1969 many years ago and had no problems ......
