Mini Shakes When I Turn It Off
18 replies to this topic
#1 Nathan86Mayfair
Nathan86Mayfair
  • 49 posts
Posted 02 August 2012 - 03:45 PM
Sometimes when i turn of my Mini it shakes a bit and the ignition light flutters. Im pretty new to Mini's and was just wondering if this is normal with the A Series engine and if there was anyway of stopping it.
Many thanks
#2 jamiestevenbell
jamiestevenbell
  • 637 posts
  • Local Club: DCMOC
Posted 02 August 2012 - 03:49 PM
no its whats called running on but it can be caused by stale fuel, how olds your fuel?
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 02 August 2012 - 03:52 PM
just lift the clutch up a bit as you turn the key
#4 Nick Warwick
Nick Warwick
  • 1,588 posts
air/fuel mixture could be out
Edited by Nick Warwick, 02 August 2012 - 03:53 PM.
#5 Mini-Mad-Craig
Posted 02 August 2012 - 03:53 PM
A shakey Mini? Are you kidding? This.Is.Mad. :crazy: :crazy:
#6 hobnob888
hobnob888
  • 375 posts
Posted 02 August 2012 - 03:54 PM
it sometimes happens to me when i leave the choke on by accident so its still got fuel in the carb
#7 thebullet
thebullet
  • 1,337 posts
Posted 02 August 2012 - 04:40 PM
Leaving the choke on? Not the best thing to do, even by accident.
#8 hobnob888
hobnob888
  • 375 posts
Posted 02 August 2012 - 04:43 PM
i knoiw
I know :( i just forget its on sometimes
#9 jaydee
jaydee
  • 8,565 posts
Posted 02 August 2012 - 05:03 PM
I take it you're talking about run-on issues.
Before stopping, put it in gear, push the brakes and slowly depress clutch as you turn the engine off, this is a good 'work around' to the problem.
A decoke to the cylinder head may cure the problem, which can be caused by wrong mixture/ingition.
Even a modified cylinder head with 'hot spots' on the chambers may cause the problem.
#10 charie t
charie t
  • 3,153 posts
.............so its still got fuel in the carb
It should always have fuel in the carb
#11 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 02 August 2012 - 05:20 PM
You mean lift the clutch. Depress = press.
#12 jaydee
jaydee
  • 8,565 posts
Posted 02 August 2012 - 05:24 PM
Yep!!
Sorry for confusion..
#13 freshairmini
freshairmini
  • 1,718 posts
Posted 02 August 2012 - 05:30 PM
Does it matter if they run on tho a little, is there actually any adverse effects to the engine, apart from making you look a little silly. :D
I think mine has an anti-run-on vale that dumps loads of air into the bores when its turned off to dilute the remaining fuel and air.
#14 dave-88_123
dave-88_123
  • 302 posts
  • Local Club: jurrasic coast minis
Posted 02 August 2012 - 06:43 PM
i had this it was pre ignition as the timing was slightly out
#15 glowpot
glowpot
  • 88 posts
Posted 02 August 2012 - 07:04 PM
If it's an SPi injection engine then it could be one of the vacuum hoses leaking.
Or if it's a carburettor engine then make sure the choke linkeage on the carburetor isn't sticking, mine did and this caused the idle to be too high. This caused it to run on (making the Mini engine shake the way you described).
