what size socket??
15 replies to this topic
#1 davexdavexdave
davexdavexdave
  • 650 posts
Posted 16 March 2006 - 09:59 PM
what size socket do i need to get the hub off. im changing my discs and im fairly sure i dont have one big enough!
#2 THedooBZ
THedooBZ
  • 887 posts
Posted 16 March 2006 - 10:15 PM
i went to halfords and bought a 33mm metric impact socket to put on my breaker bar, there is a specific imperial size but imm not sure what it is but the socket i got works fine.
you will need an extra person to pump and hold the brakes to undo the nut, putting into reverse helps aswell, just incase u didnt know.
#3 Steve@RetroDash
Steve@RetroDash
  • 1,163 posts
Posted 16 March 2006 - 10:25 PM
1/5 16 socket. does the hub nut and subframe tower bolts and i think maybe the steering wheel nut
#4 Lomcevac
Lomcevac
  • 275 posts
Posted 16 March 2006 - 10:26 PM
Inch and five sixteenths.
#5 kada1980
kada1980
  • 608 posts
Posted 16 March 2006 - 10:32 PM
1" 5/16
#6 minislapper
minislapper
  • 1,957 posts
Posted 16 March 2006 - 10:36 PM
There is NO equivalent socket size in mm. You will ultimately end up trashing your socket, the nut/bolt and putting yourself at risk as the socket is not a perfect fit. Spend the few quid more and get the correct sized socket.
#7 Lomcevac
Lomcevac
  • 275 posts
Posted 16 March 2006 - 10:42 PM
1/5 16 and i think maybe the steering wheel nut
Yep and the crank pulley. Buy one!
#8 davexdavexdave
davexdavexdave
  • 650 posts
Posted 16 March 2006 - 10:46 PM
yep thats what i wanted to know thanks alot
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 16 March 2006 - 11:44 PM
Still trying to do this using the brake?
Take the wheel off, remove centre cap and hub nut split pin, put wheel back on and put car back on ground. Now put it in gear and loosen the nut, you'll find it much easier with the weight of the car and the tyre friction helping than with the brakes. Don't be foolish and try to do more than loosen it with the weight of the car on the wheel! It would be hard to do but if you managed to get the whole CV out with the car on it's wheels it'll fall on you. You can do it back up this way too, but do remember the split pin.
And yeah, it'll damage the nut pretty quickly using a 33mm socket at 150lbft and you could get hurt when it slips off.
Edited by Dan, 16 March 2006 - 11:46 PM.
#10 syholl
syholl
  • 710 posts
Posted 17 March 2006 - 07:23 AM
Unless of course somebody has changed the nuts at some point, for the newer type ones that you can buy at all the shows.
They require a 34mm socket, and nothing else will fit.... Right PITA when you don't have one in your collection...
#11 Jammy
Jammy
  • 25,397 posts
Posted 17 March 2006 - 09:19 AM
I think I use a metric socket, might be a 33mm, its a *very* tight fit, and usually needs a light tap of a hammer to get on. But it doesn't damage the nut or the socket. I have a socket set that has both metric and imperial (tis quite old now), I usually use the imperial, but will always try the metric equivlent, and if the metric is a tighter fit I'll use that. I can't see if the metric is a better fit how it will damage the bolt or socket.
#12 neil_g
neil_g
  • 880 posts
Posted 17 March 2006 - 09:25 AM
as jammy says, ive used a 33mm on the tower bolts and steering wheel nut before and its a nice tight fit.
#13 kada1980
kada1980
  • 608 posts
Posted 17 March 2006 - 09:29 AM
1 5/16 = 33.337mm
#14 neil_g
neil_g
  • 880 posts
Posted 17 March 2006 - 09:55 AM
must be a 0.3mm manufacturing tollerance on the halfrauds socket then.. lol
#15 THedooBZ
THedooBZ
  • 887 posts
Posted 17 March 2006 - 02:52 PM
well i aint had aproblem with the 33mm so il use it until i do,. i had the wheels off loadz of times and no probs.
i would buy the correct size but when i got the tool for free who cares.
