Are All Diffs The Same?
4 replies to this topic
#1 mister bridger
mister bridger
  • 912 posts
Posted 03 August 2012 - 04:29 PM
Obviously ratios vary but otherwise are all crownwheels and pinions the same? ie no difference between A and A+, remote or magic wand box etc
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 03 August 2012 - 04:38 PM
No there are differences, for example you cannot use an A series crownwheel or pinion with an A+ equivalent, also each crownwheel is designed to be used with only one tooth count pinion.
#3 mister bridger
mister bridger
  • 912 posts
Posted 03 August 2012 - 04:46 PM
But as long as they are a matched pair they will fit?
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 03 August 2012 - 04:57 PM
dimension wise and what they fit onto, yes completely compatible through the whole range...
However, don't try and put a CWP from an auto in a manual as it wont fit, nor try and put a longer final drive than a 3.4 in a remote or Magic wand without modifying the bearing retainer, as the pinion wont fit in the hole.
You'd need one of these http://www.guess-wor...play.htm?id=148
#5 mister bridger
mister bridger
  • 912 posts
Posted 03 August 2012 - 05:04 PM
Currently have a 4.13 ratio and it screams its head off. Would 3.4 be the best to go for? It's A+ 998 on remote box, 10" wheels
