Where Are The Drain Holes
12 replies to this topic
#1 chrisdeakin
chrisdeakin
  • 151 posts
Posted 03 August 2012 - 05:00 PM
I have a 1993 mini sprite , just wanted to know where the drain holes should be in the side panels as its been blacked off and I could do with some drainage !
Many thanks chris
#2 tiger99
tiger99
  • 8,584 posts
Posted 03 August 2012 - 10:51 PM
What do you mean by side panels? Are you referring to the sills? Apart from the door bottoms, they seem to be the only places where drainage is provided, and it is via the pressed flutes on the bottom. If these are blocked, it is because you have oversills fitted, which will rapidly ruin the car if not removed, as they will accelerate corrosion in the inner sill and even the heelboard ends.
Edited by tiger99, 03 August 2012 - 10:51 PM.
#3 chrisdeakin
chrisdeakin
  • 151 posts
Posted 04 August 2012 - 07:10 AM
Erm I'm not 100 sure I assume there the slots a third in from each side , and how do I know if I have over sills or not , don't mean to sound stupid but we all have to learn haha
#4 rodandtom
rodandtom
  • 998 posts
Posted 04 August 2012 - 08:34 AM
Hi,
I am doing the body of my '94 Sprite and I found that somone had fitted oversills. Trust me - you want to get them off and quick. Usually they are fitted to hide rust thats already there and then slapped over with a load of underseal to get through an MOT or because someone wants to sell the car on without doing the work properly. I only found out I had them because I had some rust in the front and rear arches and had to strip the underseal off. I found that they hadn't welded the rear end of the oversill. The other telltale signes were inside the car. There were unexepcted marks and paint with some kind of sealant in one or two patches. Plus I had a rust hole on the inside that didnt have any kind of correspopnding rust on the outside - it just made me suspicious.
I'm afraid the only way you are going to know is get the underseal off and have a good poke around.
RodAndTom
Edited by rodandtom, 04 August 2012 - 08:35 AM.
#5 chrisdeakin
chrisdeakin
  • 151 posts
Posted 04 August 2012 - 11:33 AM
How do I get them off?
#6 miniyellowmini
miniyellowmini
  • 595 posts
Posted 04 August 2012 - 11:39 AM
I am currently in the process of doing this job.
http://www.theminifo...sprite-project/
#7 rodandtom
rodandtom
  • 998 posts
Posted 04 August 2012 - 03:32 PM
Just grind away the old welds - its a slow jb but it lets you do it without too much damage to whats underneath - just in case its not too bad.
RodAndTom
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,092 posts
  • Name: Neil
Posted 04 August 2012 - 03:36 PM
Oversills
#9 joeyfinneran
joeyfinneran
  • 511 posts
  • Local Club: imoc
Posted 05 August 2012 - 10:54 AM
And are normal sills just the same or what ?
just confirming what i have
#10 sonikk4
sonikk4
  • 16,092 posts
  • Name: Neil
Posted 05 August 2012 - 11:57 AM
These are normal short sills from M machine
#11 Klevdo2202
Klevdo2202
  • 615 posts
Posted 05 August 2012 - 12:06 PM
Everywhere on most models! =P
#12 chrisdeakin
chrisdeakin
  • 151 posts
Posted 06 August 2012 - 09:24 AM
What kind of cost would it be to have them taken off? And then what to sort rust if there is any ?
#13 sonikk4
sonikk4
  • 16,092 posts
  • Name: Neil
Posted 06 August 2012 - 05:43 PM
Not the answer you are wanting to hear but how long is a piece of string??
If and its a big if the old sill was removed then the rust damage may be minimal like on my Clubman, however if the old sill is still in place then you may need to replace the complete inner sill, the jacking point , both inner slinging brackets and possibly repairs to the heel board end.
This will not be cheap and i would hazard a guess at somewhere around the £600 mark. It maybe more it maybe less. Obviously if you can weld then its your time plus parts.
