To check which coil you are running look at the wiring
If the coil as a white/pink and a white/yellow wire then it is a ballast coil.
You can use either a ballast coil or a non ballast with the conversion kits. You alter the wiring to suit.
option 1..Ballast coil...keep the coil wiring standard do not remove any wires.
The new conversion kit, run the black wire to the coil negative, the red wire you run a new 12v ignition fed feed to it, take a feed off the white wires on the fuse box. do not connect the red wire to the coil
option 2..If your system is Non ballast as standard then its easy connect the red wire off the conversion to the coil positive, the black wire to the coil negative.
option 3...convert a ballast system to non ballast ...remove the white/pink and white/yellow from the coil positive....run a new coil positive feed from the white wire on the fuse box...coil negative keep standard.....now connect conversion as in option 2 above.
Edited by lrostoke, 06 August 2012 - 08:29 AM.
