Wont Start, Fuel Help
15 replies to this topic
#1 josh austin mini city e 82
  • 505 posts
Posted 07 August 2012 - 01:28 PM
hi mini gurus yet another problem to report with my mini!
here go's i drained my fuel tank the other day took it off and drained all the fuel out of it as it had been stood for about a year with the same fuel in the tank, changed the fuel filter too as the old one looked a bit tired.
fueled it up about 2 days later then didnt touch it for about 3 days, came to it this morning on my day off to see if it would start.. but no luck. the main thing i have noticed is that there is not fuel in the fuel filter.. so no fuel is getting to the carb, but why is beyond me, spent about 2 mins turning the car over waiting for fuel too full the filter but nothing then my battery died >_<
i have no idea what the problem is so any help is more than useful!
my car is a 1982 city e
998cc
hs4 carb
if that helps
#2 richw911
richw911
  • 2,084 posts
Posted 07 August 2012 - 01:48 PM
Faulty pump?
#3 josh austin mini city e 82
  • 505 posts
Posted 07 August 2012 - 01:51 PM
cant see why it would just go faulty with me removing/replacing the tank and filter though?
#4 firefox
firefox
  • 1,102 posts
  • Local Club: will find one when on the road
Posted 07 August 2012 - 02:56 PM
is it electric or mechanical fuel pump
#5 josh austin mini city e 82
  • 505 posts
Posted 07 August 2012 - 08:41 PM
Honestly not sure :-S i think its mechanical ...
#6 Carlos W
Carlos W
  • 10,115 posts
Posted 07 August 2012 - 08:47 PM
How much fuel did you put in?
The outlet isn't right at the bottom of the tank so put a gallon or so in
#7 firefox
firefox
  • 1,102 posts
Posted 07 August 2012 - 08:50 PM
Have a look on the subframe under the fuel tank, and see behind the engine right hand side looking at it
#8 josh austin mini city e 82
  • 505 posts
Posted 07 August 2012 - 08:56 PM
its on the right of the engine
and i only put a 5er in so what 4liters?
#9 Carlos W
Carlos W
  • 10,115 posts
Posted 07 August 2012 - 08:57 PM
probably closer to 3.75 litres
I'm not sure that's enough!
Start simple
#10 josh austin mini city e 82
  • 505 posts
Posted 07 August 2012 - 09:01 PM
start simple i like it, ok ill tear into my wallet and put £10 in should be more than enough
i realy hope it isnt the fuel pump ...
#11 Carlos W
Carlos W
  • 10,115 posts
Posted 07 August 2012 - 09:02 PM
£10 will be more than enough!
I'd love to be right!
#12 josh austin mini city e 82
  • 505 posts
Posted 07 August 2012 - 09:04 PM
i hope you are haha, ill let you know anyway cheers for the help!
#13 Carlos W
Carlos W
  • 10,115 posts
Posted 07 August 2012 - 09:09 PM
If that doesn't work, confirm what type of pump you've got as above, also try with the filler cap off, and check for kinks in the fuel pipes!
#14 josh austin mini city e 82
  • 505 posts
Posted 09 August 2012 - 09:51 PM
got it working! think my pump is starting to die, i just helped it a bit and sucked some fuel up through the fuel filter ! all is well
#15 jaydee
jaydee
  • 8,565 posts
Posted 09 August 2012 - 10:50 PM
Fuel filter? You wont see it full of petrol!! :tumble:
Your engine doesnt start, so its stone cold and you can do this test:
Detach the fuel inlet at the carb float chamber, and have a mate switching the starter on for just a couple of seconds. If fuel doesnt pour out of the pipe, you can have either a leakage somewhere or a fuel pump failure.
