Plate On The Back Of The Disk
9 replies to this topic
#1 Jonty
Jonty
  • 52 posts
Posted 08 August 2012 - 08:13 PM
i dont know the full word for this but do you need them on for an mot as upgraded brakes done have them i know they are there for a reason but was just wondering as mine has just snaped on the bracket and mot is soon
#2 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 08 August 2012 - 08:15 PM
I'm not sure for an MOT but you're supposed to have them to stop stones and dirt getting into the disc?
#3 Jonty
Jonty
  • 52 posts
Posted 08 August 2012 - 08:18 PM
k thank you il have to look in to it
#4 dave-88_123
dave-88_123
  • 302 posts
  • Local Club: jurrasic coast minis
Posted 08 August 2012 - 08:23 PM
mine went through a mot recently without them as they dont fit with vented discs and it seemed ok
#5 Cerberus
Cerberus
  • 989 posts
Posted 08 August 2012 - 09:13 PM
Alot of people don't bother with the brake shield, mainly because they break, and then rattle against the disk.
A positive is that without them, you might get a bit more air flowing over/at the disk.
A slight negative can be that water can more easily get splashed against the disk, which unless your brakes are getting super hot, I doubt would make much difference.
I've not had any problems with mine after removing them last year when I renewed the brakes.
Edited by Cerberus, 08 August 2012 - 09:14 PM.
#6 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 08 August 2012 - 09:16 PM
Chuck em. They rust in no time and rattle on the disks and don't aid cooling at all. Can trap stones between themselves and the disc faces making horrible scraping/grinding noises.
Quick once over with the grinder and they are gone :D
#7 Cooperman
  • 23,513 posts
Posted 08 August 2012 - 09:25 PM
I have always taken them off and chucked them in the bin. They don't serve any useful purpose except to act as a trap for rust and stones. They certainly don't affect the braking efficiency, which is all the MoT requires.
In fact, they are just an unnecessary nuisance.
#8 mike.
mike.
  • 6,176 posts
Posted 09 August 2012 - 11:18 AM
The only possible advantage I can think to them is in really wet weather not as much water will spray onto the disk. May help on a motorway when you drive for a while without braking.
#9 Cooperman
  • 23,513 posts
Posted 09 August 2012 - 08:16 PM
To be honest I've never had any issue with the brakes in the wet without those shields. It really doesn't make any difference at all so far as I can tell.
#10 bmcecosse
bmcecosse
  • 9,699 posts
Posted 09 August 2012 - 08:53 PM
We had to fit the shields to get Mini through Gp 2 Scrutineering - where they helpfully suggested that the shields can be bent away from the disc - to make a very useful cold air scoop.......
