Fitting Drive Flange To Brake Disc (7.5 Cooper S Conversion)
11 replies to this topic
#1 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 08 August 2012 - 09:32 PM
Okay so my minispares 7.5 cooper S disc conversion arrived today!! :D
When trail fitting the drive flange to each of the brake discs though, they don't seem to fit and slide down over the four wheel studs on each disc very easily. I'm sure I could probably get them to fit with some heavy handed persuasion, but I don't want to damage the threads on the studs.
Anybody else experienced this problem, or is there a problem with my particular kit?? :unsure:
#2 richw911
richw911
  • 2,084 posts
Posted 08 August 2012 - 09:44 PM
Normal just needs a bit of persuasion, and when fitting the nut will draw the last bit it in tight :proud:
#3 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 08 August 2012 - 09:49 PM
What's your preferred form of persuasion??... When I persuade things it tends end badly and involve replacement parts!! >_<
#4 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 09 August 2012 - 12:29 PM
I think the drive flange should nearly drop straight on, with no persuasion at all. It needs to be screwed to the disc before putting it on the car and tightening the hub nut. I think there is a tolerance issue on AVV IT's parts.
#5 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 09 August 2012 - 04:12 PM
Okay emailed Simon at Minispares and apparently it's because some of the studs on the discs aren't straight on. It seems that I need to take the studs out, fit the flange, and then draw the studs back through.
Does any body have any advice on how best to remove the studs though, I assume it's just a case of knocking them back through, but I again I don't want to damage the threads. :unsure:
#6 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 09 August 2012 - 05:00 PM
This isn't the case, assuming yours are the same as mine- they go half way and then get tight.
If they start then they're in the right place. Few taps with a copper mallet should do the trick :thumbsup:
#7 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 09 August 2012 - 05:04 PM
Nope, I can't get the flange over the four studs at all, let alone half way!!
#8 The Otter
The Otter
    The artist formally known as j322overthetop
  • 620 posts
Posted 09 August 2012 - 05:10 PM
Mine get tight about halfway down, then need a few hits with a rubber mallet and they're on fine.
#9 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 09 August 2012 - 05:12 PM
ahh, guess you'll have to whip the studs out then =]
#10 richw911
richw911
  • 2,084 posts
Posted 09 August 2012 - 06:23 PM
Same for mine :proud:
Maybe yours will need the studs to come off AVV IT? be interested to know how you sort it :proud:
#11 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 09 August 2012 - 08:36 PM
Thanks for your input guys!! :thumbsup:
I had a go at removing the studs, but that just looked like it was just going to end badly and probably result in needing eight new studs. So working on the assumption that the studs were probably going to end up being toast anyway, I figured "what the hey" and used a bit of gentle persuasion to locate the flange over the studs, involving some copper grease, a large mallet and a piece of timber!!.....
......10 minutes later and it's "Job done" and the threads are all ok too.... Happy Days!! :proud:
Edited by AVV IT, 09 August 2012 - 08:37 PM.
#12 richw911
richw911
  • 2,084 posts
Posted 10 August 2012 - 04:11 PM
Ah great stuff :thumbsup:
