Hello all,
Having problems with my 1980 Mini Austin, 998.
It simply will not start when hot.
If i crank the engine over the starter motor disengages without the engine starting.
If the engine does manage to turn over and start it only "chugs" for maybe 2 - 3 turns and dies.
If i keep persevering it finally starts"chugging" then with help for the accelerator finally gets to some higher RPM's to actually start running.
The whole process can keep going for up to 5 mins before actually starting the car.
I have had the head refurbished a couple of months ago but have only been having the above problems for a couple of weeks.
Wont Start When Hot.
smee56
, Aug 08 2012 11:30 PM
6 replies to this topic
Posted 08 August 2012 - 11:30 PM
Posted 08 August 2012 - 11:45 PM
See if you're getting a spark at the plugs first, but it sounds like a fuelling problem. Do you know what pattern of starter motor you have, inertia or pre-engaged?
Posted 09 August 2012 - 04:04 AM
Sparks at all pugs, and unkown what type sorry. How would one check?
Posted 09 August 2012 - 05:13 AM
Could be vapor lock. Do you have a heat shield between the carb and the manifold? Is the fuel line too close to the exhaust?
Posted 09 August 2012 - 10:36 AM
Inertia has a remote solenoid
bolted to the inner wing.
Pre engaged, the solenoid is built in to the starter motor so the battery cable goes straight to it.
I mention this as your car probably has ballasted ignition which is supplied via the solenoid when the starter is cranking. Pre engaged starters try to disengage themselves electrically when the engine starts, so that may be an issue. It could also be the ballasted supply (white/pink wire) breaking down when hot.
You could try bypassing the ballast with a wire connecting the coil +ve to a white wire at the fusebox, but don't use this as a permanent fix, it'll overheat the ignition.
Posted 10 August 2012 - 06:33 AM
No heat shield and inertia starter, Fuel line was not to close but was still fairly warm.
Posted 12 August 2012 - 05:55 AM
Put the heat shield on for a start, they're there for a reason, especially on the HiFs.
