Clutch Problems Any Ideas ?
Posted 09 August 2012 - 02:34 AM
slows the engine down about 200 to 300 rpm I have replaced the slave cylinder with a new one
at first i could not get any gears at all so a made a longer push rod and now i can drive the car
but the idle still slows down and the dredded 3rd to 2nd crunch is still there and all syncro rings were replaced as this condition existed before a rebuilt the box
Any ideas or advice
Thanks in advance
The Lime in Canada
Posted 09 August 2012 - 06:47 AM
Do you mean the baulk rings have been replaced in the gearbox? or the syncro hub? or both?
Posted 09 August 2012 - 09:37 AM
I changed the baulk rings,main shaft, second gearDid you adjust the clutch when installed? the two large nuts on the end of the operating shaft govern how much throw or travel the thrust bearing can go. In effect sounds like you have too much travel and are forcing the crankshaft hard against the thrusts at the opposite end of the engine this will cause long term problems. Check the gap between the nuts and the clutch cover, by making a longer push rod you will only make the problem worse.
The engine slows down with the standered push rod and i'm not able to get any gears with that set up
I am pulling my hair out
Thanks for the reply
The Lime
Posted 09 August 2012 - 11:45 AM
Is the crankshaft endfloat OK?
Posted 09 August 2012 - 02:31 PM
yes as far as i know
I did'nt have this problem before i rebuilt only changed the main thrust bearings
Posted 09 August 2012 - 08:28 PM
I actually think that the primary gear may be partially siezing on the crankshaft, so even if the clutch plate is fully disengaged, the drive is not. I have seen that once.
Surprisingly, no-one has asked you if it is a Verto or pre-Verto clutch. That makes a very big difference, the pre-Verto should have a stop bolt near the slave cylinder which must be correctly adjusted, and if that was missing it could explain why you had to extend the push rod.
Posted 09 August 2012 - 08:43 PM
Its a pre verto clutch it has the bolt/stop which ive adjusted as per the haynes manualThere is something very contradictory here. Pushing the clutch slows the engine, yet making the push rod longer, to push it more, does not?
and the rpms were dropping when i had the shorter push rod in
When I took it for its first test run everthing worked just like it should
Went for petrol an hour later coudnt get any gears atall
had to start it while in gear and was able to get home but coudnt change down
put the longer push rod in now i can drive it change down exept from 3rd to 2nd and ive change all the baulk rings
at a total loss
Thanks The Lime
Posted 09 August 2012 - 08:49 PM
Posted 09 August 2012 - 08:57 PM
Fitted a new second gear , main shaft and baulk ringsThe gap to the little 'stop' is best at 15 thou, with the arm held away by hand (return spring removed). Then i suggest you bleed out the hydraulics. Did you ONLY change the baulk rings - or did you also fit a NEW 2nd gear?
Thanks The Lime in canada
Posted 09 August 2012 - 08:59 PM
But you still have another problem.
Posted 09 August 2012 - 09:06 PM
Undo the two large nuts in the centre of the clutch cover. These are the overthrow stop nut & locknut.
Set the stop bolt clearance to 0.015" when pulling the clutch arm by hand witht he spring removed.
re-fit the spring and check that the top of the clutch arm has a linear movement of 0.55" +/0.050" from clutch pedal full up to clutch pedal fully down. If it does not move this amount then there is a hydraulic problem or a problem with the pedal linkage.
If that movement exists, push the clutch pedal fully down and screw in the inner overthrow stop nut until it just touches the cover. release the pedal and turn that nut a further 1/2 a flat. Use the locknut to lock it in that position.
The clutch is now correctly set. If there are still problems with selecting gears come back on here.
Posted 09 August 2012 - 10:16 PM
I did fit original baulk rings but why did it work fine on the first test run and now it crunchs from 3rd to 2ndDid you fit an 'original' baulk ring - or a pattern item? But could just be air in the system - not freeing the clutch properly, hence the crunch. Does it double-de-clutch ok without crunch?
double clutching does not work either
Posted 09 August 2012 - 10:21 PM
I've set the clutch as you suggested and i can select gears no problem when changing up the box and down untill it comes to
changing down from 3rd to 2nd thats why i changed the baulk rings in the first place
Thanks the Lime in Canada
