Hi,I need a new battery for my mini and I need a more beefy one as I have new digital clocks,alarm system ect fitted.
The engine is a 1275 M.G Metro but I need a battery that will fit in the battery box.
Can anybody help?
AL
What Battery For My Mini?
minicity1275
, Aug 09 2012 07:16 PM
6 replies to this topic
Posted 09 August 2012 - 07:16 PM
Posted 09 August 2012 - 07:19 PM
i have fitted an halfords ho63 cost about £60
Posted 09 August 2012 - 07:32 PM
http://www.carbatter...60AH-I1002.html
lot beefier than the above and fits no problem
063
Premium Car Battery
Voltage - 12V
Capacity - 44Ah
CCA(SAE) - 360A
Dimensions(mm)
210 x 175 x 175
075
Premium Car Battery
Voltage - 12V
Capacity - 60Ah
CCA(SAE) - 525A
Dimensions(mm)
242 x 175 x 175
063
Premium Car Battery
Voltage - 12V
Capacity - 44Ah
CCA(SAE) - 360A
Dimensions(mm)
210 x 175 x 175
075
Premium Car Battery
Voltage - 12V
Capacity - 60Ah
CCA(SAE) - 525A
Dimensions(mm)
242 x 175 x 175
Edited by lrostoke, 09 August 2012 - 07:33 PM.
Posted 09 August 2012 - 07:36 PM
Varta battery can't go wrong
Posted 09 August 2012 - 07:41 PM
Great,thanks for the replies.
I will use this info and get a "beefier" battery
Alan
Alan
Posted 09 August 2012 - 07:51 PM
Digital clocks and alarm should have negligible effect on the electrical load. If you really did need a larger battery for that reason, you would also need an uprated alternator.
But it is still a good idea to uprate the battery, because it will be winter soon, and starting will be easier.
Posted 10 August 2012 - 06:18 AM
Thanks for the advice:)
