The micra has a standard 'in the tank' fuel pump, now im looking at an aftermarket external one, so whats best? i have found that 3 bar of fuel pressure is common in fuel injection esp the micra. What about flow rates? because aftermarket ones say good for upto 150hp and im like i only going be making around 90 or so... so will i stress the regulator out if i run more or worse hold the injectors open or run to rich?
So what fuel pump would you recommend?
Swirl pot or not?
Any help is muchly appreciated thank you
www.funkmotorsport.com
Edited by smudger068, 10 August 2012 - 03:17 PM.
