Rod Change Steady Bush Removal
3 replies to this topic
#1 Spitz
Spitz
  • 1,716 posts
Posted 14 August 2012 - 04:58 AM
I can't get the outer part of this bushing out.
The rubber has disintergrated.
I've removed the inner piece.
I've tried punching it out but with no success. I have managed to mangle the casing slightly
Engine is in the car by the way
This is the part in case you're not sure what I'm talking about..lol
http://minispares.co...ic/13h7286.aspx
Help
#2 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 14 August 2012 - 07:53 AM
they are not very easy to get out, even with them out of the car and in a vice
i had to try and crush the sides in and then use a 11mm socket to go round it and hammer it out
they are hard thats all i can say but try hammering the side inwards to make it smaller
#3 Surfbluegarage
Surfbluegarage
    AKA mini_mad_daps
  • 1,547 posts
Posted 14 August 2012 - 07:59 AM
as said abouve quite hard on the car to do these little buggers are in a vice i end up knocking the centre out like you said you have already then using a deburing bit on a die grinder weaking one side of it then tap the opposite sides with punch to collapse it onto its self then it drops out.. wiether or not you have access to it enough to do this.... ?
#4 HafMan
HafMan
  • 383 posts
Posted 30 August 2012 - 08:39 PM
Ive JUST dont this and what a headahce! It took me hours O_O
Now i've put a new one in and i can only select 4th gear >_< Could the bush be slightly off-center?
Sorry for the hijack
