Speed!
27 replies to this topic
#16 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 14 August 2012 - 04:05 PM
did RR make a difference as ive never done mine since i s1k it, i just co test and make sure plugs are fawn
is yours standard tho thurt you had a s1k on it
Yes stage 1 kit fitted & Rolling Roaded... maybe shave a few seconds off it :lol:
#17 konyo
konyo
  • 1,107 posts
  • Local Club: Mini Freakz of Sussex
Posted 14 August 2012 - 04:15 PM
HUGE Difference! Just put your foot down and it's keeps going & going. I would show you if I lived nearer to you. Defiantly worth getting yours set up though :) You won't regret it.
Edited by konyo, 14 August 2012 - 04:17 PM.
#18 Chance
Chance
  • 1,457 posts
Posted 14 August 2012 - 04:27 PM
I put my foot down and it goes 'nope not going anywhere'
Put it through the floor and it picks up
Slightly rich I think
I'd rolling road it but it's fully standard :P
Oh and have you tested yet?? :)
Edited by Chance, 14 August 2012 - 04:38 PM.
#19 Cooperman
  • 23,513 posts
Posted 14 August 2012 - 05:15 PM
I did some 0 - 60 tests in my 'S' on an airfield with a level runway and tested both ways to remove the wind-speed error.
It averages 0 - 60 in 7.4 seconds using just 1st & 2nd and changing up at 7000 rpm, and 8.5 using 1st, 2nd & 3rd and changing up at 6500 rpm. That's with around 115 bhp at 6400 rpm. Of course, wheelspin is the problem. I run a SC CR gearbox with a 3.9:1 FDR.
#20 Chance
Chance
  • 1,457 posts
Posted 14 August 2012 - 05:20 PM
I would like about 10secs 0-60
Guess I'd need around 80bhp??
#21 Cooperman
  • 23,513 posts
Posted 14 August 2012 - 05:36 PM
Depending on the FDR, that sounds about right. With lower gearing you might do it on 70 bhp, but that would limit your top & cruising speeds.
#22 Chance
Chance
  • 1,457 posts
Posted 14 August 2012 - 05:39 PM
I only have a 998 atm, completely standard engine wise. I guessworked it and its a 998 A+ with 3.105 FD. I think this is more suited for cruising??
#23 Cooperman
  • 23,513 posts
Posted 14 August 2012 - 06:05 PM
The acceleration of a 998 is limited by the lower torque compared to a 1275 and by the high FDR.
The old 998 Cooper had a 3.76:1 FDR and with 55 bhp it could do 0 - 60 in around 16 seconds. The original 1275 'S' with 75 bhp had a 3.76 FDR which was soon changed as standard to 3.44. It gave around 11 seconds 0 - 60 which in 1964 was stunning.
Still, the 998 is a very smooth engine and will cruise all day at 4000 rpm+.
#24 cooperrodeo
cooperrodeo
  • 379 posts
Posted 14 August 2012 - 10:02 PM
I hope none of you is relying on the speedo to give an accurate indication of speed. It is quite likely that the speedo reads 10% high.
#25 Cooperman
  • 23,513 posts
Posted 14 August 2012 - 10:08 PM
I use my accurately calibrated rev counter.
#26 Spitz
Spitz
  • 1,716 posts
Posted 15 August 2012 - 01:21 AM
Got my 1130 to 145 the other day ( clocked by GPS ) That's with a 3.1FD, didn't think to look at the tach.
( not positive what that is in the old fashion mph...lol )
#27 Doz1971
Doz1971
  • 209 posts
Posted 15 August 2012 - 08:29 AM
My speedo is currently broken, and I'm not sure whether it's more accurate like that or not O_O :D :D :D :D
#28 Cooperman
  • 23,513 posts
Posted 15 August 2012 - 06:09 PM
90.5 mph.
