Adjusting Hi Los?
Jakeclubby
, Aug 14 2012 11:28 PM
22 replies to this topic
#16
Posted 22 August 2012 - 04:05 PM
You don't have a hi lo there matey. It should be where the cone shaped thing is, that's the standard trumpet.
#17
Posted 22 August 2012 - 04:37 PM
Wow looks like ive been made a full out of a bit there maybe i only have them at the back
#18
Posted 22 August 2012 - 04:38 PM
Always kinda thought my car was near standard height
#19
Posted 22 August 2012 - 08:06 PM
Also...like said earlier...check what type you have ( if you have them )
If you have the original Hi-lo on the rear, then you would have to drill a hole either side in the rear valance to fit the long 3/8" adjuster ( just a 3/8" allan )
Hi-Lo is a proper name that just started being used ( incorrectly ) to describe any adjustable cones.
Originals do not have the adjusting nuts ( aprox 1" ). They just have a small allan lock screw and the 3/8" allan on top. ( On a MkIII+ the large subframe tower bolt needs to be removed for adjusting.
#20
Posted 22 August 2012 - 09:31 PM
So there could still be adjustable cones??
#21
Posted 22 August 2012 - 09:34 PM
There could be in the back...you'll have to check.
But those in the front look like stock non adjustable....
#22
Posted 22 August 2012 - 09:38 PM
Ok im gonna have to lookThere could be in the back...you'll have to check.
#23
Posted 22 August 2012 - 09:57 PM
At the front, no, you do not have hi-lo's.
