10's On A 1.8 Vvc Mini ?
Posted 15 August 2012 - 12:16 PM
any experiance or are 12,13's best for big power minis?
thanks joel,
Posted 15 August 2012 - 12:32 PM
Posted 15 August 2012 - 05:26 PM
The last one I was in was spinning 13" wheels at 70mphseen a few projects with 10's but always thought they would be a nightmare to drive wheel spinning and toping out at about 80 mph lol
thanks joel,
Posted 01 October 2012 - 05:47 PM
Fit a gearbox from a diesel Rover. You can even get one from a Freelander which would higher the gearing more still...
Posted 01 October 2012 - 06:32 PM
Posted 02 October 2012 - 10:32 AM
This is an easy fix.
you sure, they have huge (compaired to a mini) wheels and to be any use off road I would have thought that they would be geared shorter. Plus there is teh 4x4 system in it that would make it interesting
If you keep the metro bearbox, then that is set up for 185/55/13's, so not a big % drop down to mini tyres.
Posted 02 October 2012 - 10:35 AM
Posted 02 October 2012 - 04:04 PM
Posted 02 October 2012 - 06:06 PM
lsd is available for both, just the pg1 had it in some rovers as standard, so easier to get a hold ofPG1 means you can have a LSD
Posted 05 October 2012 - 01:32 PM
Posted 05 October 2012 - 07:26 PM
not sure if i've seen it under a standard round nosea pg1 is a bit of a squeeze tho isnt it ?
Posted 05 October 2012 - 10:38 PM
On the plus side, the lack of grip makes it hard to break drive shafts and splines.
JD
Posted 06 October 2012 - 11:59 AM
Posted 19 October 2012 - 06:59 AM
You can go over the top and fit a freelander box, which is also PG1 but after a discusion online, probably not the best of ideas.
http://www.16vminicl...ead.php?t=30542
Posted 06 November 2012 - 12:59 PM
unless you want to make a frakenstein box of course
VVC with PG1 under a round nose is possbile :) im nearly there ;)
