Door / Check Arm Seal Leak
6 replies to this topic
#1 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 15 August 2012 - 01:28 PM
It's raining. I wouldn't usually mind but today I notice a pretty heavy drip coming from the bottom of the passenger door, over the rubber door seal and into the footwell via the carpet. I guess it's stemming from the hole in the bottom of the door as it lines up pretty much with this - where is this hole supposed to drain to?! I don't really understand. How to stop it coming inside?!
P.S. I replaced my door check arm seals a couple of months ago with foam ones, and last month I took the door cards off and re-duct-taped the access holes in the inner door while I was at it.
Thanks >_<
#2 lewBlew
lewBlew
  • 1,238 posts
Posted 15 August 2012 - 05:14 PM
OK had another look and I think water is making it's way through a small pitted area in the bottom edge of the door. Anyone else had this?
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 15 August 2012 - 06:45 PM
Is the bottom of the door rusty, if so this could be your problem.
#4 lewBlew
lewBlew
  • 1,238 posts
Posted 15 August 2012 - 07:09 PM
Yep! Repair panel? Needs new door outer skin too. Not sure what will be more economical, new doors or to repair/replace it all!
#5 sonikk4
sonikk4
  • 16,168 posts
  • Name: Neil
Posted 15 August 2012 - 07:17 PM
For me i would repair and reskin but then i can weld. Not only that i would be 100% sure all of the rust is removed plus all of the extra protection i would add between the skin and door frame.
#6 invisible_kid
invisible_kid
  • 516 posts
Posted 15 August 2012 - 07:50 PM
My knighmare too
#7 lewBlew
lewBlew
  • 1,238 posts
Posted 15 August 2012 - 08:29 PM
