Brake Discs
14 replies to this topic
#1 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 15 August 2012 - 05:53 PM
Does anyone know if these can be used with standard calipers?
http://www.minispare...px|Back to shop
#2 Surfbluegarage
Surfbluegarage
    AKA mini_mad_daps
  • 1,547 posts
Posted 15 August 2012 - 06:00 PM
need at least the metro 4 pot calipers with drive flanges to suit.
#3 Cooperman
  • 23,513 posts
Standard Metro 4-pot calipers are what you use as the discs are much thicker than the solid ones.
GBC2031 is the part no. of the RH caliper, but can't find a ref to the LH side.
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 15 August 2012 - 06:36 PM
Thought that may the case. Thanks
#5 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 15 August 2012 - 07:05 PM
Cooperman, do you have experience of these:
http://www.minispare...ack to shop#pab
I know in theory they will cool better and scrub the pads but was wondering of there is any noticeable difference in the real world.
#6 fishey798
fishey798
  • 562 posts
  • Local Club: Mini Rebels
Posted 15 August 2012 - 08:13 PM
Dont bother with the drilled/dimpled and grooved discs, they are just noisier! Just fit a good quality set of standard discs and quality pads.
#7 Cooperman
  • 23,513 posts
Posted 15 August 2012 - 08:39 PM
Remember that the Mini is a very light car, so the braking system only needs to be able to stop around 750 kg loaded weight. Most of the braking issues I've encountered, with the exception of drum brakes and the 997 7" disc brakes, have been caused by poor condition/quality discs and/or 'cheapie' brake pads.
Unless the car is to be used for long-distance racing the standard discs are fine. However, they must be genuine original quality and material, not 'Chinese monkey-metal' ones and if you want top quality pads then Mintex 1144 are best with the 8.5" discs or 'carbon-metallic' ones for the 7.5" 'S' brakes. With 8.4" discs I've used Mintex 1177 material and have even had the discs glowing red hot without any loss of braking capability (you do have to change the wheel bearing grease more often when you do that).
Personally I use AP600 brake fluid in the rally cars, but for road use DOT4 is fine.
The ability to stop the car to the limit of adhesion of the tyres is the most you need, as above, although those actually making a profit from selling the more expensive brakes would have you believe otherwise ;D .
#8 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 16 August 2012 - 07:19 AM
Is that these ones:
#9 jaydee
jaydee
  • 8,565 posts
Posted 16 August 2012 - 09:33 AM
Yes there for standard 2 pot calipers, but you want solid discs for them, dont use carbon metallic pads over grooved/drilled disc.
#10 Cooperman
  • 23,513 posts
Posted 16 August 2012 - 10:13 PM
They are absolutely ideal.
These are the brake discs - Mini Spares part number: 21A2612MS
#11 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 17 August 2012 - 07:50 AM
Thanks guys
#12 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 22 August 2012 - 07:52 PM
Fitted the Mintex 1144s and new discs today. They aren't bedded in yet but already the feel is transformed, cheers Cooperman.
#13 Cooperman
  • 23,513 posts
Posted 22 August 2012 - 09:14 PM
To bed them in, drive along in 3rd gear at about 45 mph. Press the throttle to the floor and use your left foot on the brake pedal to keep the speed the same. Do this for about 1/4 mile (no more than that). Allow the brakes to cool and repeat that about 4 times. Then the M1144's will be properly bedded in.
I hope this helps.
Edited by Cooperman, 22 August 2012 - 09:14 PM.
#14 jaydee
jaydee
  • 8,565 posts
Posted 22 August 2012 - 09:23 PM
Apply GENTLE pression to the brake pedal if you're not confident with left foot braking.
#15 minimissionary
minimissionary
  • 999 posts
  • Local Club: Fylde Mini Club
Posted 22 August 2012 - 09:26 PM
I have them on the Surestop grooved discs. They squeak like hell. Is this the worst of the side effects?
