Some of it is easily fixable (a crossed wire somewhere making the lights not work when the ignition is off and a loose drivers seat)
However, the major part was "the breaks bind on to the point you can hardly move the wheels". Sure enough when i picked it up, it wouldnt move when it drove fine on the way there.
Then i noticed the pedal was half pressed, kicked it and all was fine.
What could be the problem? is it a master cylinder failure or is there a spring somewhere that needs adjusting/lubricating?
Oh, and it also failed on its emissions, CO level was too high, is this just a case of adjusting the mixture?
On the upside, my clutch seems to have sorted itself out
Thanks again
Edited by mattbeddow, 16 August 2012 - 11:45 AM.
