the engine had a lot of rust in it - old owner just put water in - no antifreeze / corrosion inhibitor
I flushed engine , & put rad / block cleaner in it , got most of it out
then I stripped engine & pressure washed the block & back flushed / scrubbed the rad
all hoses new & heater matrix flushed / scrubbed
run a drill thru block & head holes (same size) to clean them up
bottle brush thru various holes - complete clean up
after rebuild put in 2 l of good antifreeze / inhibitor in
engine run fine - coolant clean - antifreeze visable
6 mths on - coolant is dark / rusty again
stripped head off - rust visible in block again
it's almost as if I am using sea water as coolant
I recon water jacket must have a lot more in it
what do you lot recon - run it / flush it / run it / flush it ?
car isn't going to be on the road for a few years
Edited by sledgehammer, 17 August 2012 - 01:47 PM.
