Which Lead Additive
Posted 19 August 2012 - 11:04 PM
http://www.halfords....yId_255221#tab1
CASTROL VALVEMASTER PLUS octane booster
OK everyone got a question. I drive a 1275 '84 Mayfair. I'm running out of lead additive for my motor and my local Halfords doesn't sell the bottle that originally came with the car and i'm running a bit low, there were these two that caught my eye (Brands listed above) but was not to sure on which one two use. So I was hoping if some one could help me out on which brand they use or recommend one of these anything would help, would be appreciated thank you.
Posted 19 August 2012 - 11:37 PM
That said, they're both good, castrol valvemaster has a great reputation and many people use that.
Posted 20 August 2012 - 09:44 AM
The millers one treats only 50lt of petrol IIRC while the castrol treats 250LT...
Gotcha, Thanks Jaydee thats the one I figured just wanted to double check maybe other possible opinions.
Posted 20 August 2012 - 06:02 PM
Posted 20 August 2012 - 07:29 PM
Posted 20 August 2012 - 08:58 PM
You can get it a fair bit cheaper than Halfords on ebay and the like.
Posted 20 August 2012 - 10:42 PM
Posted 20 August 2012 - 11:28 PM
Both Castrol and Millers are highly reputable companies, unlike some of the quack remedies, snake oil, etc, which used to be sold, and still are in a few places, which did not work, and in many cases caused damage.
Stick to the one that you choose, for the life of the engine, or at least until it has a head job and hardened seats.
Posted 20 August 2012 - 11:53 PM
Posted 21 August 2012 - 12:56 AM
Ideally you should use an additive with similar chemistry to the previous one. There are several types, and they don't necessarily work well with one another. You may, or may not, get a little bit of valve seat recession while the effect of the original additive is purged from the system and the new one takes effect. I would suggest comparing what it says on the containers. What was the original?
The original bottle was REDEX lead additive.
My 1275cc motor
Posted 21 August 2012 - 12:58 AM
I would also recommend Valvemaster Plus - although if you have a standard spec engine there is Valvemaster which costs a couple of pounds less per bottle than Vlavemaster Plus.
If I use the standard valve plus and do have standard engine is that not a good thing?
Posted 21 August 2012 - 04:18 PM
Castrol Valvemaster is fine for engines with a compression ratio of 10:1 or less. Above that it's advisable to either use premium 97 or 98 octane petrol with Castrol Valvemaster, or 95 octane with Castrol Valvemaster Plus. Above about 10.5:1 you need both 978 octane and Valvemaster Plus for best results. The Valvemaster Plus has an octane booster which raises the octane number.
Posted 21 August 2012 - 08:12 PM
These sacks are a typical example of what I called snake oil. Avoid.
Posted 21 August 2012 - 08:16 PM
Posted 22 August 2012 - 01:04 AM
HAHA so what your saying is I just need the regular valve master then?
