Need To Let Off Steam
11 replies to this topic
#1 station31
station31
  • 202 posts
  • Local Club: Caledonian Mini Club
Posted 23 August 2012 - 11:41 PM
Sorry if this come across as a bit ranty. Its been a bad "Mini" day
1000 miles ago I had the CV joints replaced, done by an Mini Specialist in Glasgow, I used them often and knew well and trusted them, that Relationship came under some strain after them "Forgetting" to do work I'd asked for and quoting for further work I disagreed with, I.e replacement Subframe, it doesn't need one. This has since been checked and was found to be perfectly safe and solid
A few days ago I noticed really bad clicking on turning just as I'd heard before the last CV joints were done, I took it to a recommended by a friend to a Good garage scheme places, . I was told the CV's were bone dry no grease on them at all and also the gaiters had split I saw this for myself. Twice the CV had to be replaced in a matter of months. This garage also worked on the carb as the jet at the bottom, Mixture adjustment was stuck.
The new garage also warned against a small oil leak they'd found, I knew about this one but was putting it off as it appears to be leaking where the engine and gearbox join (automatic).
Picked it up today,after some inital cutting out after reving, a slight further mixture adjustment was done felt great on the way back, Idling a bit fast in netural but steering and car felt happy.
Got back 5 miles turned car off a massive oil leak from the right hand side, it was rainning what looked like the bottom of gearbox, it looks like that seal I was warned about had finally split.
So peeded off I cant tell ya
Thanks for letting me vent, its sitting outside wetting itself
#2 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 24 August 2012 - 07:34 AM
Its good to have a rant every now and then mate.
I was taken for a ride by an individual who really should have know better,he and his so called business were so -called experts and in reality turned out to be no more than a silly little boy,no more than some card board cut-out incompitant fool.
However there was light at the end of the tunnel,and i eventually found a company who actually knew what they were talking about,so i feel your frustration.
Did you go back to the original garage and explain to them the problems that have since been discovered??
#3 SA MINI
SA MINI
    Previously known as shaunarmes.
  • 1,001 posts
  • Local Club: yet to join HAMOC
Posted 24 August 2012 - 07:40 AM
You say the oil is leaking from where the gearbox joins the block.
This is what my auto used to do. I actually had a good look when I had the engine out & still do it regularly now it's on the road. Is check the bolts aren't loose. Mine at the start were so loose . Now I just keep my eye on a couple of bolts. & now have no leaks
Hopefully your gaskets not gone completely.
If its still leaking when it's not running though I'd suggest looking at your driveshaft oil seals or diff gasket
#4 station31
station31
  • 202 posts
Posted 24 August 2012 - 12:13 PM
We had words come MOT when it passed and to my mind it shouldn't, there was play in radius arm indentified by the tester, Mini speciist just regreased it, and it passed mmmmm really ?? my thoughts were if its worn, replace it, It was suggested I might want to furnish the tester with a crate of beer, I was horrifed at this, and firmly said "The cars either safe to use or its not" I got the impression he couldn't be arsed.
Some of you may remember my question about subframe replacement I was quoted 25 hrs for the job,same guy. I'm lead to belive and you can do it 7-8 hours.
This guy has seen me go from a fit-ish fella to a guy who now uses a mobility scooter and hasn't worked since. Since the accident I really struggle to do even a basic servcie, it took me 7 hours to reset tappets, a normal 20 minute job.
Guess the guy thought aah ha easy money £££, Just because I cant do the work anymore, doesn't mean I didn't know how to before, well some things, in order to check where the leak is I had to get someone to take photos and show me.
One thing I learned theres and lovely genuine people in the mini world, but theres some utter gits too
#5 Merryck
Merryck
  • 339 posts
Posted 24 August 2012 - 02:05 PM
The same can be said for every part of society. The trick is to remove the 'gits' (some of my vocabulary is a little bit bluer here!) from your life.
If it's a matter of you knowing how to do the work but not being able, is there a relative or relative of a friend who is interested in cars? I find young enthusiasts are always raring to get their hands on an actual car and it provides them with some serious inspiration. Particularly with jobs like the tappets, something quite easy, where all you really need is someone able to push the car about.
Could be an answer to your problem, partially at least - I wouldn't be putting an amateur up to the task of swapping a subby over :D
#6 Rhys
Rhys
  • 898 posts
Posted 24 August 2012 - 03:29 PM
Seems like a lot of people are out to take you for a ride. Been done to me a couple of times by people highly regarded in the scene.
#7 station31
station31
  • 202 posts
Posted 24 August 2012 - 05:08 PM
Gits was the polite version, Its a family show in here :D
The current problem its currently outside wetting itself
Edited by station31, 24 August 2012 - 05:08 PM.
#8 RawlinsGTR
RawlinsGTR
    Formally known as Dog
  • 1,046 posts
Posted 24 August 2012 - 07:21 PM
#9 SA MINI
SA MINI
  • 1,001 posts
Posted 24 August 2012 - 08:22 PM
That looks like its either the gasket gone or it's come really loose on the gear selector housing (there's also an engine mount on that plate aswell). Or it could be the gear selector shaft seal
#10 1984mini25
1984mini25
  • 8,787 posts
Posted 24 August 2012 - 08:37 PM
25 hours for a subframe, I need to take more tea brakes. I managed to swap one over the other week. In 6 and a bit hours, witch I didn't think was bad going considering I injured my back a month or two back.
#11 DEXISWOLF
DEXISWOLF
  • 545 posts
  • Local Club: Steel City Classics
Posted 24 August 2012 - 10:20 PM
i know how you feel well not as bad as yours but still annoying after an hour and half me and my grandad finally got to p&l minis for some group 5 euros to be told they sold the last set this morning so i was looking at other arches and wanted the extra wide wood and picketts and mr p was being helpfull saying my wheels (7x13s) will stick out a bit but not much plus me and my dad put them on another mini with 7x13s on but then we got interrupted by mrs l by sayin no they wont fit so mr p carried on saying there fine ive put them on before then mrs l again saying well your an engineer and there not so they wont beable to fit them because wing needs cutting so mr p just said well its upto you ******* so i said yeah ill have them then again mrs l AGAIN to say we havnt got any in stock even tho 5 minutes before they had loads :angry: so after all that i came but with nowt sorry for the long rant it was needed
#12 station31
station31
  • 202 posts
Posted 24 August 2012 - 11:04 PM
You know how it goes I'll forgot about all the crappy stuff when its as sweet as a nut again, I'd just had the CV replaced yesterday and it felt great, then this, wheres its going Tues they have a great name been working on minis since the 60's so I guess we'll see
