How do you fix gel cracks in carbon fibre
Posted 19 March 2006 - 10:32 PM
Posted 20 March 2006 - 05:11 PM
almost impossible to repair, as even if you gouge a groove and fill with resin then flat back ,it will allways crack in the same place again,.How do you fix gel cracks in carbon fibre? looing at getting a bonnet but it has a crack in the middle of it and was wondering if it can be fixed
carl
Posted 20 March 2006 - 05:48 PM
I bought a GRP front end from curley now while i am very happy with the qualitity and to be honest it fits very well just needed a minimal amount of sanding to fit properly. there are some chips in the gel coat most of the are not in a place that people will see but i still know they are there. would it be ok to put a bit of filler on these chips and then sand them down prime and paint?. they are only chips and i think most of them is probally me when pulled it out from storage.
Posted 20 March 2006 - 09:06 PM
Posted 20 March 2006 - 09:19 PM
Posted 20 March 2006 - 10:54 PM
Posted 20 March 2006 - 11:01 PM
Posted 21 March 2006 - 02:40 AM
I agree that it'll be next to impossible to fix cracks though. I tired allsorts on my old GTM and they kept re-appearing!.
Posted 21 March 2006 - 04:02 AM
carl
This is just not true! You can sand it back - re apply matt, resin or gel coat and it will be as good as new! Of course it will crack if you just fill it with resin. It's a two part process and you have to use both the parts when you make repairs. Ie: Resin and glass/carbon/kevlar fibres
... and Mine and Ade's cars are testament to that. Check the cover of MiniMAG for proof! Could you see any cracks from the front end collision damage that was repaired on his car?
Posted 21 March 2006 - 08:10 AM
thats a good point why didnt i think of that before, i remember when looking at ades website that it had a crack in it and was repaired so obiously it is possible, but yeah u want to use f/g resin and not normal filler when done properly it will be as strong as original.
a bit like if you weld a panel properly it wont crack in the same place again.
you did say its a carbon fibre one originally, i am assuming you mean carbon on the inside with white gel coat outside and not exposed carbon weave????
Posted 21 March 2006 - 09:19 AM
Thanks everyone
Posted 21 March 2006 - 08:42 PM
im not an expert on fibreglassing but i would say with the weave being exposed you would probably end up with a more noticable mark than at present, if it was a gel coat top it would be worth it as you could always spray it.
but anyway that is out of the question.
dont suppose you have a picture of the crack do you????
this way people may be able to offer better advice if they can see the item itself.
if you are happy though, leave it be and forget its even there otherwise it'll stick out everytime you look at it.
Posted 21 March 2006 - 09:05 PM
Posted 26 March 2006 - 03:12 PM
