Won't Start After Engine Swap.
Posted 26 August 2012 - 11:25 AM
When I turn the key and just get the solenoid click. The only electrics that where removed from the swap, was the starter, alternator, coil and dizzy. I thought the battery was too flat to turn the starter. Not the case I tried bumping it with my missus car.
Am I missing something. All the earth straps have good connections.
She fired up well before the swap too.
Any help or pointers to look at would be good.
Paul
Posted 26 August 2012 - 11:27 AM
Also, when jumping, are you letting the battery charge for 5 minutes before you turn the key?
Posted 26 August 2012 - 12:41 PM
Did the engine turn over easily before the engine was fitted ?
Also is the starter corect for the new engine ? What type of flywheel did your old engine use ? Is it the same as the new one?
However it is most likely to be eletrical
Edited by MiniElliott, 26 August 2012 - 12:43 PM.
Posted 26 August 2012 - 01:05 PM
Just removed the starter to try and release it, very smooth and easy to turn.
I was using an inertia starter which was working fine, although I have the newer engine with a pre engaged motor I swaped it to see if the starter was fubar.
Just put everything together again and lost all ignition power. The power to non Ignition (lights) work.
Is there an unline fuse that may have blown?
Also with the pre engaged starter dose it need the one power point? Like the inertia one?
Just lost for where to look, as the electric are a real mash up.
Posted 26 August 2012 - 02:06 PM
But if you have gone from having a separate solenoid on the inner wing to a piggy back style, you need to do a bit of rrewiring. Or the simple way i've got round it is to leave the wing mounted solenoid as is and just make up a cable for the new starter motor.
You just join the large bolt for the main power on the stater motor with a short bit of wire to the large spade connector on the solenoid. Then everything works as normal without any major rewiring.
Posted 26 August 2012 - 02:07 PM
If the battery terminals and earths are ok, next thing is to check and clean the main battery connection at the solenoid, the thick black battery cable, which will also have a bunch of brown wires on the terminal. These are the live feeds to the alternator, ignition switch and light switch etc, and are unfused. One of these brown wires may be adrift, or corroded or broken at the terminal.
Check that when you turn the key, you get 12V on all the white circuits (ignition switch controlled, no fuse).
Posted 26 August 2012 - 05:01 PM
What ampage wire would you use, obviously quite a high rating?
Can I not just use the bolt which holds the cable going straight to the starter?
This would save fabricating a spade connector?
Posted 26 August 2012 - 05:07 PM
I think I've burnt out the solenoid as I have lost all power, not even a click. But I'm getting the battery charged over night before I do anything too rash.
Posted 26 August 2012 - 06:00 PM
It does also mean you now have 2 solenoids, but it's a lot easier than having to extend wires or if you ever need to switch back.
But I never had any problems with doing that way, as all the wing mounted solenoid does is switch the stater on and off and the later fires the pinion into the ring gear of the flywheel.
Edited by 1984mini25, 26 August 2012 - 06:03 PM.
Posted 26 August 2012 - 07:36 PM
