A Mini Tool Kit
13 replies to this topic
#1 HafMan
HafMan
  • 383 posts
Posted 27 August 2012 - 05:51 PM
Ok, so i'm looking at expanding my tool kit because i'm fed up of getting half way through a job and realising i'm missing a tool >_<
So what do you guys recommend for a mini orientated tool kit?
I've been looking for some imperial rachet spanners but i cant find any, without paying a bomb for :mmkay:
Tom
Edited by HafMan, 27 August 2012 - 05:55 PM.
#2 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 27 August 2012 - 06:03 PM
^ what the hell?
#3 HafMan
HafMan
  • 383 posts
Posted 27 August 2012 - 06:08 PM
^ what the hell?
Tools for a mini.
Like any particular socket sizes etc
#4 tiger99
tiger99
  • 8,584 posts
Posted 27 August 2012 - 06:16 PM
1/2" and 9/16" are the most used sockets, always worth having a spare of each, as they sometimes get damaged by a reluctant nut.
#5 HafMan
HafMan
  • 383 posts
Posted 27 August 2012 - 06:20 PM
Ok cool just making up a list now that i've got some cash left over from the mini parts that i need and my wages :shifty:... i must've added up wrong
#6 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 27 August 2012 - 06:30 PM
look at the complete tool kits in machine mart
also get a decent torque wrench and compression tester
brake adjusting spanner ( little square one)
#7 Cooperman
  • 23,325 posts
Posted 27 August 2012 - 07:46 PM
And make sure you get Imperial size spanners. so many people think they can 'make do' with metric ones which seem to be near to correct - they are not.
You need 7/16", 1/2" and 9/16" AF as the basic sizes, plus some others like 5/8", 11/16" and 3/4". The sump plug is 15/16" AF.
#8 Big_Adam
Big_Adam
  • 7,435 posts
Posted 27 August 2012 - 08:15 PM
More 1/2inch spanners than you think. I started with 6, I now have 2 I can use on anything and 4 "specialised" ones I've ground down, chopped and ruined.
#9 jakejakejake1
jakejakejake1
  • 644 posts
Posted 27 August 2012 - 08:47 PM
As everyone has already said, don't try and do an imperial job with a metric tool as you can round off the bolt/ nut/ your knuckles.
I recommend this socket set: http://www.halfords....tegoryId_255215
if you won't be doing much/ only occasionally, as it provides brilliant valve for money, obviously if you were doing this as a job or something you would want higher quality stuff, but for home use you cant complain. I have had this set for around two years now and haven't broke any of it.
And some spanners like this: http://www.amazon.co...ASIN=B000LFVKN0
Although to be fair for a couple quid more you could get: http://www.amazon.co...ASIN=B000LFVKTO
Which has most of the spanners you will need, but with a load of metric chucked in for when you need to do other stuff.
#10 Cooperman
  • 23,325 posts
Posted 27 August 2012 - 09:04 PM
The one on Amazon looks good value, but note that it doesn't have a 15/16" for the sump plug. Ah well, you can't have everything!
#11 jakejakejake1
jakejakejake1
  • 644 posts
Posted 27 August 2012 - 09:09 PM
I do use an adjustable spanner for the sump plug, my reasoning is that they shouldn't be used on anything that needs to be very tight - which prevents me from over tightening the sump plug as many people do. Well that's my excuse for being stingey and not buying the proper spanner :)
#12 ukcooper
ukcooper
  • 1,625 posts
Posted 28 August 2012 - 08:43 AM
Socket sizes
1"1/2 Deep= Ball joints / Gearbox internal / Flywheel
15/16" = Sump plug
1"1/8 = Gearbox internal / Drum Brake Hub Nut / Crank Pulley Bolt
1"3/16 = Verto nut
1"5/16 = Crank pulley / Hub nut / Tower Bolts / S-Wheel Boss
11/16" = wheel nut's
1" = oil releaf nut
and
12v electric test light
Edited by ukcooper, 28 August 2012 - 08:49 AM.
#13 oliver122
oliver122
  • 1,007 posts
Posted 28 August 2012 - 09:06 AM
i went to machine mart and brought a few bits all with a lifetime guarantee on them , a 18" breaker bar , 2 sets of metric spanner 1 normal 1 stumpy and 2 sets of imperial as well 1 normal 1 stumpy , also have one of the big sockets sets from halfords which has a life time guarantee on this one : http://www.halfords....tegoryId_255215 but they do come up on offer from time to time so can get them quite cheap, and get a set of screwdrivers as well ive got a halfords set but thinking of getting a machine mart set with a lifetimee guarantee . i didnt buy all my tools at once brought them as i go along so i could buy quality stuff that will last and ive managed to pretty much every task ive come across so far
#14 freshairmini
freshairmini
  • 1,718 posts
Posted 28 August 2012 - 10:15 AM
I got a whole load of Draper tools. Pretty good quality and they have a huge range of metric and imperial. Maybe try some US manufacturers as their going to be more likely to have a better range of imperial tools, so you may be able to find some imperial ratchet spanners.
to be honest tho ratchet spanners are good but not essential. Get a good set of imperial sockets and a good ratchet. Will do most jobs. also Draper do a pretty cheap set of imperial spanners, about £15-£20 I believe.
