Hey guys, wondering if you could help me out...............AGAIN!
This week my my car isn't running so great. When I drive it it seems to shudder below 3000rpm and has very little power. I have to bring the revs right up to at least 4rpm before changing gear and even then it doesn't have the power. It doesn't sound too good either, sounds like its being restricted. I have a slight feeling that it may be something to do with the distributor. I would ask the father but sadly he's on holiday.
Any ideas?
Thanks in advance
Adam
Shuddering And Loss Of Power
adam davies
, Aug 28 2012 09:44 PM
7 replies to this topic
Posted 28 August 2012 - 09:44 PM
Posted 28 August 2012 - 09:47 PM
What type of dizzy are you running, electronic or points??
Posted 28 August 2012 - 10:16 PM
Inspect all ignition parts: earth strap, dizzy clamp, coil connections, dizzy cap, HT leads. Try a different coil and replace points and condenser or, if you have the later leccy dizzy, try a different ignition module.
Posted 28 August 2012 - 10:29 PM
As above, check the ignition. Do the symptoms change when different loads are put on the engine?
Check that you're getting a spark on all plugs.
Posted 28 August 2012 - 11:54 PM
Oil in dash pot?
Posted 29 August 2012 - 10:11 AM
we had a good look in work just now and one of the mechanics has come to a conclusion that something has gone inside the engine such as a valve seal. Thankfully I'm halfway through building my new engine so I think I'll crack on with that instead of trying to fix this engine. Thanks for replies guys
Posted 29 August 2012 - 01:23 PM
Valve seal??
No club member near you who can lend an hand on this?
Posted 29 August 2012 - 03:07 PM
Did you check this?Oil in dash pot?
I doubt a valve seal will cause any shuddering! a bit of smoke from the exhaust maybe but not the symptoms you describe.
