cylinder head
Posted 20 March 2006 - 06:27 PM
i know blue mini does some but never been able to get hold of him and how much should i expect to pay for big valve and mild port work to the correct compression ratio?
thanks lee
Posted 20 March 2006 - 06:50 PM
What CR are you running?
Posted 20 March 2006 - 07:05 PM
if you want to get the compression ratio right though, you are gonna need some seriously big chambers in there!
Posted 20 March 2006 - 07:12 PM
1380 i have flat top pistons
ive got 11cc dish omegas and 20.5 in the head
Posted 20 March 2006 - 07:51 PM
the block has not been decked to the pistons so i thought i could have a head made to suit...
can it be done?
thanks lee
Posted 20 March 2006 - 07:53 PM
Posted 20 March 2006 - 07:55 PM
i dont know thats why i need a head to suit and someone with experiance to make it... can it be done?
Yep, according to Vizards 'bible' 26cc was max in the head, but people have gone up to 31cc on turbo ones (IIRC). It also depends on the piston fitted. It may have a slightly lower crown height. The best thing to do is set the pistons up at TDC and measure the capacity of the block (the piston could be sitting lightly lower in the block than standard ones do).
Seriously though, it can be done. It's worth trying to get an ID off the pistons and talking to some engine builders like Morspeed or Bill Richards etc.
lee
Posted 20 March 2006 - 07:59 PM
i've got morspeeds number was gonna try them tomorrow but i'l try med too to compare prices they wont need the block will they just bore and swept volume ?
lee
yeah, like I said, if you measure the block CC or give them a piston ID it should be enough for a quote. Also, measure the height from the block face to the piston crown (when at TDC), it's easy enough to calculate an approximate block volume from that with flat tops.
Posted 20 March 2006 - 08:00 PM
or wait for one of the tech's to poast on here
Posted 20 March 2006 - 08:12 PM
But really need more info to be more sure.
Posted 20 March 2006 - 11:40 PM
this is the picture of the piston, i have not removed them as i dont have the ring compression tool i cannot see any markings on them from the top they sit pretty close to the top of the block at tdc i'l measure them later i'd say 2mm max probably not even that far with my veriers i checked the bore and i got 73.5mm is that about right could be dodgy measuring though i dont have a bore mic
thanks for all your help i'l get back to you with quotes to see what you think
Posted 20 March 2006 - 11:49 PM
Posted 21 March 2006 - 07:40 AM
As for 100hp, possible at the fly, but don't expect it at the wheels..
