Spi Running Rough And Puffing Black Smoke
7 replies to this topic
#1 0138dave
0138dave
  • 190 posts
  • Local Club: west mids minis,tmf+
Posted 31 August 2012 - 04:19 PM
Hi all my spi has all of a sudden decided to play up at idle it is puffing not purring and there's black smoke coming out the exhaust any ideas and seems to be eating fuel?
#2 icklemini
icklemini
  • 2,982 posts
Posted 31 August 2012 - 08:57 PM
map sensor pipework most likely split...
temp sender may have gone bad...
#3 0138dave
0138dave
  • 190 posts
Posted 01 September 2012 - 04:43 PM
Could I use silicone vac pipes for this???
#4 joecefnhedog
joecefnhedog
  • 45 posts
Posted 22 January 2014 - 05:25 PM
mine is having the same problem, did you solve this problem?
#5 FlyingScot
FlyingScot
  • 2,664 posts
Posted 22 January 2014 - 07:57 PM
Attached File  image.jpg   45.36K   3 downloads
Suggest you have a look through this section.
FS
#6 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 22 January 2014 - 08:12 PM
FS
:lol:
#7 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 22 January 2014 - 10:22 PM
black smoke would indicate running rich, the cause could be many things, but I would always start with the basics; is the car in good serviceable condition? are the tappets set to the correct clearance? is there a good strong spark at each plug?
#8 joecefnhedog
joecefnhedog
  • 45 posts
Posted 25 January 2014 - 04:15 PM
Just had this exact same problem, turned out to be that the map sensor pipework had been taped up and wired the wrong way, it was touching the exhaust manifold and was melting. Sorted now :)
