Idle Air Control Valve And A Diagnostics Reader
8 replies to this topic
#1 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 31 August 2012 - 07:02 PM
Hi all,
My MPI won't idle below 1500 and at times goes right up to 3000 when driving, tried all sorts - air leaks, temp sensor, map sensor.....
the question I have is will a faulty idle air control valve show up on a diagnostics reader? I have removed and cleaned, and replaced the housing as the original was cracked, (also tried a different IACV, not new though).
I have plugged it in to a diagnostics a few times over the last couple of days and its showing no errors.
Any thoughts?
#2 icklemini
icklemini
  • 2,982 posts
Posted 31 August 2012 - 08:58 PM
am thinking an air leak...
warped throttle body perhaps holding the butterfly open...
#3 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 31 August 2012 - 10:20 PM
throttle body replaced, not new but from a freinds running mpi. cant find an air leak, all good there i think.
it points to the iacv, but this isnt showing as a fault on the diagnostics, im not sure if it should?
#4 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 01 September 2012 - 08:34 AM
anyone?
#5 icklemini
icklemini
  • 2,982 posts
Posted 01 September 2012 - 03:07 PM
in my experience it wont show a 'fault'
#6 charie t
charie t
  • 3,153 posts
Posted 01 September 2012 - 03:11 PM
Hi all,
Any thoughts?
I have one doing exactly the same,
if it is not working iacv will show up, if its sticking it won't show up
#7 liam_italian
liam_italian
  • 1,417 posts
Posted 01 September 2012 - 07:26 PM
Try cleaing the IACV. Also I would look for a vacuum leak around the throttle body, especially where the inlet meets the cylinder head. Best way is to spray a little carb cleaner over the areas when the engine is running. If there is a leak you'll hear a slight change in the revs.
#8 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 01 September 2012 - 08:18 PM
Thanks guys. I tried another used IACV today, from an MGF (they are the same) this made the idle a lot better, still a little high though. I'll check for leaks again.
#9 liam_italian
liam_italian
  • 1,417 posts
Posted 01 September 2012 - 10:41 PM
Is your throttle cable correctly adjusted?
