Group 4 Arches
kez_19
, Sep 01 2012 04:34 PM
9 replies to this topic
Posted 01 September 2012 - 04:34 PM
does anyone have any pictures of group 4 arches from huddersfield mini spares fitted especially at the ends of the front arches i cant seem to work out how they should fit
thanks in advance michael
Posted 02 September 2012 - 11:53 AM
am i the only one that has bought these arches ??
Posted 02 September 2012 - 12:24 PM
i have them heres some pics
Posted 02 September 2012 - 12:42 PM
Great i was starting to think I was alone do you have any pics of the ends of the arches as I am not sure where they fit
Posted 02 September 2012 - 05:03 PM
arnt they group 5?? like mine?..........
Posted 02 September 2012 - 07:23 PM
mine are group 4 (at least thats what i ordered from them) the main problem i have is where the arch meets the strip that goes between the wheel arches along the side of the car the arches touch this strip not allowing the arches to sit up against the body as i want them to do.
i know that i couls simply grind off a bit of the steel strip but is it necessary or is it just me that doesn't have them in the correct place ??
also they seem to sit quite high up on the steel wings meaning that i have alot of steel showing behind the arches are the arches meant to be cut back as the arches are meant to be used for 12" wheels and i have 10"
thanks michael
thanks michael
Posted 03 September 2012 - 12:04 PM
are you on about this area....circled below
Posted 03 September 2012 - 12:28 PM
Yeah exactly there
Posted 03 September 2012 - 12:31 PM
they can sit above it or you can cut a little notch out for the seam to slot into, i'l get some better pics of the arches when i'm home if it helps
Posted 03 September 2012 - 12:49 PM
Great thanks I think I will grind off a bit of the lip but some pics will be great I will add some pics my self to show how it looks
