in car computer/tv
Posted 21 March 2006 - 09:44 AM
he has got a citroen c2
could you tell us what would be the best thing to do/get?
putting this in?
and the cost of it?
any help please, not really a whiz when it comes to things like this
Posted 21 March 2006 - 10:13 AM
You can get special power supplys that provide a stable supply of power so the computer doesn't turn off when you crank the engine and they make sure the computer boots down properly when you turn off the car.
You can either get a few types of motherboard that are smaller than your average tower computer motherboard. ITX and Micro ATX are very small and small respectively. Then you can get allsorts of LCD screens, a GPS receiver for sat nav, even wire it to your stereo.
If you were completely building a new computer with screen I'd expect it to cost ~£500. You can build it cheaper by using any parts you may already have or using second hands parts, etc.
Posted 21 March 2006 - 10:20 AM
so is it touch screen or is there some sort of controller. how would the pupils be able to awnser the questions?
Posted 21 March 2006 - 10:24 AM
Mounting in the boot is also not a problem, I've seen a few installs that do this, but then you need to connect to a monitor thats at the front of the car.
Posted 21 March 2006 - 07:27 PM
these are tiny pcs which are more than capable of running the stuff you would need and yes you can connect a touchscreen monitor aswell. you want to look at the online store, but check out some of the custom built ones like a pc in E.T.
you would be able to fit these either in the glovebox or even into the dash with some modification.
Posted 22 March 2006 - 07:40 AM
Posted 23 March 2006 - 10:12 AM
and hopefully we will get something where you don't have to do many mods to the car as we get a new one about 2-3 years
check out http://www.mini-itx.com/
these are tiny pcs which are more than capable of running the stuff you would need and yes you can connect a touchscreen monitor aswell. you want to look at the online store, but check out some of the custom built ones like a pc in E.T.![]()
been looking round that site and theres some really cool stuff
considering someof them items
Posted 24 March 2006 - 06:36 PM
the trouble with laptops is that the pupil can't use it when they are in the drivers seat and they can't really use it when it is in the passengers seat.
You don't have to use the screen., laptops come with a VGA port, so you can plug in a touch screen and use the laptop as a normal pc, if you use a docking station it's also easy to take out and use should you need to. Also, car power adapters are relativly cheap. I'll be using a laptop when I fit mine, seems a nicer solution, everything in one bundle.
Posted 27 May 2007 - 02:26 AM
Posted 27 May 2007 - 09:49 AM
Posted 23 June 2007 - 10:56 AM
Posted 23 June 2007 - 10:08 PM
Posted 23 June 2007 - 11:49 PM
Posted 24 June 2007 - 11:17 AM
Posted 12 July 2007 - 05:55 PM
And I'd recommend getting a touchscreen, just runs off vga and a usb port, and is very responsive. The forums over there have a lot of frontends available, but you could easily write your own, so you wouldn't need a keyboard or mouse.
