A quick question to those who have fitted a ETB digidash2 into a mini, where is the best place to fit the magnets for the speed sensor??
Pictures of your brackets would help
Kevin
Etb Digidash2
warning634
, Sep 03 2012 10:43 AM
2 replies to this topic
Posted 03 September 2012 - 10:43 AM
Posted 03 September 2012 - 08:26 PM
Hi,
I have just fitted mine on to the passenger side pot joint. Secured these on using an epoxy glue. Just make sure to fit the magnets the right way around! Made a sensor bracket to hold the speed sensor in place, needs to be robust to stop the sensor vibrating and loose.As the speed cable runs by the exhaust manifold I went and bought from Merlin Motorsport a heat resistant sleeve. I Have just programmed the unit tonight and I need to jack the front end up slightly to rotate the front wheel to make sure the sensor is reading okay. I will take some pictures then and if you want email them onto you.
Regards,
John (Pistonbroke)
Regards,
John (Pistonbroke)
Posted 04 September 2012 - 07:14 AM
Hi John
Many thanks for your post. I look forward to the pics and any other info that you have on the installation of digidash would be great.
Kevin
Kevin
