Correct Grease For Outer (Hub) Cv Joint
11 replies to this topic
#1 Nic
Nic
    Formally known as jonesy!
  • 1,218 posts
Posted 03 September 2012 - 03:08 PM
The CV joints from minispares do not come with any grease. The rover service manual says to pack the joint with 1oz of Duckhams Bentone Grease Q5795.
Having checked the internet I see that BP own them but nothing is made under this name anymore. I was going to use moly grease as I thought that was suitiable for CV joints. Is this ok or does anone know where to get the correct grease from?
#2 Artstu
Artstu
  • 832 posts
Posted 03 September 2012 - 03:45 PM
Moly grease is what normally comes with them, that's what I use.
#3 Nic
Nic
  • 1,218 posts
Posted 05 September 2012 - 06:39 PM
anyone else?
#4 R1minimagic
R1minimagic
  • 4,660 posts
Posted 05 September 2012 - 06:42 PM
http://www.halfords....tegoryId_165705
#5 Nic
Nic
  • 1,218 posts
Posted 06 September 2012 - 04:35 PM
sorry, not looking for places to buy the moly grease already have some. I was really wondering why the manual say to use bentone grease and not moly as there must be a reason?
#6 R1minimagic
R1minimagic
  • 4,660 posts
Posted 06 September 2012 - 05:42 PM
Thats probably just factory/dealer stuff they have in a big drum
#7 tiger99
tiger99
  • 8,584 posts
Posted 07 September 2012 - 06:33 PM
The actual grease is important. It is not just moly grease, which is inadequate. The correct stuff was the product of extensive research, and the part number is AKF1457 for a sachet. A moly grease will be expelled from the joint surfaces and end up in the gaiter, due to centrifugal force. The bentonite additive makes it stay in place where it does most good.
#8 jaydee
jaydee
  • 8,565 posts
Posted 07 September 2012 - 07:13 PM
Thats beacuse when you change the CV you're not supposed to re-use the old gaiter, but to buy a new one, the correct boot kit (unipart) contains a sachet of the correct grease.
#9 Nic
Nic
  • 1,218 posts
Posted 09 September 2012 - 09:35 AM
Thanks for the info tiger99, ill buy some sachets of the correct stuff to use. And I am not reusing the old gaiter. The CV comes with the gaiter just no grease.
#10 mike.
mike.
  • 6,176 posts
Posted 09 September 2012 - 09:53 AM
I struggle to see how a moly CV joint grease is unsuitable for the exact type of joint its made for? CV joint grease that is unsuitable for CV joints?!
All CV joints will be spinning round rapidly, so surely all CV joints that have been greased with Moly CV joint grease will suffer this centrifugal force problem?
#11 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 09 September 2012 - 11:07 AM
My thoughts exactly a bit of additive isnt going to stop it spinning to the outside considering the speeds you might be doing.
#12 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 10 September 2012 - 12:11 PM
The CV's I got from Mini Spares came pre-packed with grease. Worth having a look before you go buying any more.
