Big Rusty Hole What Panel Do I Need?
3 replies to this topic
#1 chrisg
chrisg
  • 254 posts
Posted 03 September 2012 - 07:26 PM
Hey guys and girls
I have just cut a load of rust out of the bottom of mini 1994 mayfaire and I am left with a big rusty hole under where the rear door pocket is. I have a non genuine inner sill from mini spares but it does not run down the car that far so I guess there must be anoth panel I need.
Any ideas a link would be fab if someone knows what I need and where to get it.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,095 posts
  • Name: Neil
Posted 03 September 2012 - 07:30 PM
You can either make your own out of some 0-9mm thick steel sheet or you can buy a complete inner sill from M Machine
http://www.m-machine.co.uk/cat.pdf
11.31.04.27
Inner Sill, LH, Mk1-5
£21.00
£25.20
11.31.04.28
Inner Sill, RH, Mk1-5
£21.00
£25.20
#3 sonikk4
sonikk4
  • 16,095 posts
  • Name: Neil
Posted 03 September 2012 - 07:32 PM
I deleted your second identical thread. Your answer is above.
#4 tiger99
tiger99
  • 8,584 posts
Posted 03 September 2012 - 09:13 PM
Those inner sill repair panels are potentially lethal, as they leave a gap at the seat crossmember. They are only for bodgers, and do not make any kind of proper structural repair. I find it quite depressing that such things are sold by suppliers who should know better. I only commented because I hate horrid structural bodges. You are obviously very sensible, as you intend to fix it properly.
As sonikk4 says, 0.9mm steel is one way to go, m-machine is the other.
