1275 Cylinder head, 12G840 casting.
Looks in good condition, was removed from a working car (didn’t personally see it working), has a nice coat of red paint on it. Valves are currently removed though, but are included and bagged individually, and the head is fitted with leaded seats (i believe). Last time I had unleaded seats put in it was £40, so not a major cost. Guides feel Okay though.
After £60
Cosworth intercooler
Unmodified, fits in a clubman front nicely but needs some tweaking to fit a round nose. In very good, clean condition.
£30
Seat Leon Cupra intercooler
Again in very nice condition, I flushed it through before I test fitted it to my car, which it didn't fit because of my brake servo. If you didn't have the servo it would be a great fit beside the alternator, behind the grill.
£25
Standard engine steady
Has been wirebrushed and given several coats of hammerite black. In good condition.
£5
Gunsons Carbalancer
Used for balancing twin carbs, again, brand new and in box.
£15
I also have:
Std 998 a+ camshaft £10
2 lots of simplex chains £5 each or £7 for both
A set of ford fiesta ignition leads, suitable for megajolt £10
Std, non damper crank pulley £7
Pre verto clutch slave cylinder and feed hose (banjo type) £10
Verto slave cylinder mounting bracket £3
Edited by BritishRacingGreen, 12 September 2012 - 07:54 AM.
