I cleaned the bottom of the sump a few days ago. Saturday I believe. Oil gathered where shown in the picture and seems to be the source, and theres some near the selector seal too which I will hopefully be changing on friday. I've been told I can leave the oil in for this and just jack it up at the back, is that right?
No idea to be honest i've done that with the sump dry..draining the oil is always a good idea when working on those seals, you know a facefull of oil is not very healty...
Jack up by the subframe and put it on jack stands well high so you can move comfortably under the sump and carry a big light with you, will make the job A LOT easier espescially when it comes to refit the dreaded rod change pin.
The worst part will be taking the old rubber seal off, its realy a pain but if no avail theres always a way to bodge it (put the new seal over the old and sit it flush using a deep socket, at least works,
but use it as the really last option because the next time you need to change the seals, it will be double the pain)
Get hold of this kit:
http://www.minispare...ls/MSSK050.aspxRemeber to slide the gaiter over the alloy spacer and the rod a bit.
I have to admit the rubber gaiter didnt last very long on mine but i blame it to the fact i havent fitted the sump guard extension and went out for off-road sessions (how genius am i?)
