Hif 44 Carb On A 94 35?
Posted 08 September 2012 - 11:13 PM
Been needing to know for which carb rebuild kit.
Just to check HIF means Horizontal Integral Float?
Posted 08 September 2012 - 11:15 PM
Edited by Noah, 08 September 2012 - 11:28 PM.
Posted 09 September 2012 - 12:42 AM
Posted 09 September 2012 - 01:28 AM
I've a feeling it's more likely to be a HIF38. Don't quote me on that though. HIF44s were more often used on the Cooper varieties, though I'm not too sure as to what level of tune the engine in the 35 was at. My friend has a '94 Sprite, and that has a HIF38.
Does it say it anywhere on the carburettor itself?
And the 35' is an odd set up, It had bits of SPi but it was also a carb engine - It had a catalytic converter from new? and a few other bits that I can't remember, speedo goes to 110 if thats any help
Posted 09 September 2012 - 07:32 AM
Posted 09 September 2012 - 09:35 AM
Or at least the size carb the tag came off
Measuring the hole is the most accurate, of course.
Posted 09 September 2012 - 10:31 AM
Posted 09 September 2012 - 10:32 AM
I could be wrong but I think the rebuild kit fits both. The minispares site only lists one number for both carbs.
Does a manifold fit both?, Mines lets say, a Tad rotten.
Posted 09 September 2012 - 10:44 AM
I am not sure but I think the bolt pattern is the same, but you need one with a 44mm hole or the air flow will be terrible. Most ally manifolds are meaty enough that you could open it up to 44mm.
Posted 09 September 2012 - 10:47 AM
Posted 09 September 2012 - 08:16 PM
Posted 10 September 2012 - 10:44 AM
I have a 94 35 and it's got the original HiF 38 on it.
but has a Stage 1 kit fitted. (alloy manifold) and an AAU needle.
On the RR we found that the restriction in power wasn't in the carb, but the filter (K&N in the original housing)
We couldn't get sufficient air flow to get beyond the capacity of the HiF38.
A 44 fits onto the manifold (same pattern), but was only fitted onto the pre-SPi Coopers, and had a special air filter to suit, I think
Posted 10 September 2012 - 10:53 AM
Posted 10 September 2012 - 11:37 AM
