Oil Pressure Warning Light And Buzzer
18 replies to this topic
#1 dezshearer
dezshearer
  • 441 posts
  • Local Club: mini-chat.co.uk
Posted 11 September 2012 - 08:05 PM
Hi guys, would it be safe to wire in a buzzer along with a warning light?
The sender switch wouldn't be overloaded or anything like that? It's a earth really isn't it?
#2 tiger99
tiger99
  • 8,584 posts
Posted 11 September 2012 - 08:11 PM
A small modern electronic buzzer will not require much current, so the switch will be just fine. A big old-fashioned electromechanical buzzer may be too much for it, and need a relay, but I doubt that you would want to fit one of these anyway.
#3 dezshearer
dezshearer
  • 441 posts
Posted 11 September 2012 - 08:29 PM
http://www.ebay.co.u...1#ht_1626wt_989
Something like that!
Thanks, i'll give it a shot!
Edited by dezshearer, 11 September 2012 - 08:29 PM.
#4 tiger99
tiger99
  • 8,584 posts
Posted 11 September 2012 - 09:38 PM
Yes, that should be ideal.
#5 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 11 September 2012 - 10:24 PM
I might be wrong but if you connect the buzzer to a 12VDC feed you might need to connect a diode in series with the warning light wire. The reason being is that the light power comes from the voltage stabiliser and for the buzzer from 12VDC. While the pressure switch is open there could be some voltage fed back from the buzzer to the warning light affecting all the instruments fed by the voltage stabiliser.
#6 dezshearer
dezshearer
  • 441 posts
Posted 11 September 2012 - 11:25 PM
As far as I can tell, the oil pressure warning light(brown/white) and battery charge/ignition(brown/yellow) light both run direct from the ignition live (white).
The voltage stabilizer is only used for the water temp(blue/green? It is on mine anyway...) and petrol gauge (green/black).
The oil pressure and charge lights are both "earths".. can't see why they'd need to be stabilized?
I'm only worried about shorting the oil pressure switch, and making it fuse closed!
edit: spelling.
Edited by dezshearer, 11 September 2012 - 11:26 PM.
#7 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 11 September 2012 - 11:40 PM
You are correct, my eyes are screwed up. The oil pressure warning light is connected to the white ignition wire. So, it should work like tiger said. It should only need a few milliamps.
#8 dezshearer
dezshearer
  • 441 posts
Posted 11 September 2012 - 11:51 PM
Well I'll let you guys know!
#9 1984mini25
1984mini25
  • 8,843 posts
Posted 12 September 2012 - 10:40 AM
The biggest problem is buy the time the oil light does come on, the oil pressure has already dropped to the point of doing damage. The light comes on around 8psi, but you need at least 20psi at tick over when warm...
#10 bmcecosse
bmcecosse
  • 9,699 posts
Posted 12 September 2012 - 11:17 AM
Exactly - ^^^^^ - it's a waste of time and energy........ Fit an oil pressure gauge and keep an eye on it!
#11 mike.
mike.
  • 6,176 posts
Posted 12 September 2012 - 11:30 AM
But can't you get a switch which comes on at about 15-20psi?
#12 The Principal
The Principal
  • 765 posts
Posted 12 September 2012 - 11:32 AM
Minispares will sell you a 20PSI Oil Pressure switch for £7 - http://www.minispare...|Back to search
#13 dezshearer
dezshearer
  • 441 posts
Posted 12 September 2012 - 12:09 PM
Out of stock unfortunately.
I have an oil pressure gauge, I watch it a good bit, but for those times when I'm worrying about the road, and looking out the window, I might not catch the glow of a bulb, but I'll definitely hear a buzzer.
#14 dezshearer
dezshearer
  • 441 posts
Posted 12 September 2012 - 03:59 PM
I wired the buzzer up in parallel to the light, and it worked, briefly.
Now the light won't go out and the buzzer stays on, but my oil pressure is fine according to the gauge, it's sitting at 70.
I think I shorted my pressure switch, due to fumbling about with the connectors (blue spark, so no doubt welded the switch shut at the other end).
I've ordered a new one to replace it. Poor little guy never stood a chance!
#15 Pete649
Pete649
  • 381 posts
Posted 12 September 2012 - 05:17 PM
That's true, but I had a Lotus Sunbeam track car and it used to suffer from oil surging on hard acceleration if the oil level was not topped up to a certain level (even with a baffled sump). I fitted a buzzer which drew my attention to the split second low oil pressure without me having to watch the oil gauge all the time. Worked a treat.
