im going call the local nut and bolt shop , and was going get some pins and nuts , was wondering what should i get like what sizes? any help would be great
What Nuts And Bolts Are Worth Buying ?
oliver122
, Sep 13 2012 08:50 AM
4 replies to this topic
Posted 13 September 2012 - 08:50 AM
Posted 13 September 2012 - 09:03 AM
I just bought a load of 5/16 Unf, nuts and bolts, they seem to do and fit most things,put them on your list i'm sure theres other commom sizes that people will add as well.
I was told to avoid stainless for wieght bearing bolts because they're shear rate is a lot lower than normal steel.
cheers trac
cheers trac
Posted 13 September 2012 - 09:14 AM
5/16th and 1/4inch UNF are what you want mostly.
Posted 13 September 2012 - 05:48 PM
cheers guys , well ive stripped my mini , and all my bits are in 3 different places haha , my shed , my uncles garage , and a friend of the familys shed xD so i think ive probably lost some xD
Posted 13 September 2012 - 07:37 PM
You need a selection of UNF nuts, bolts & washers. Best bet is to buy a UNF packege from Namrick Limited via their web site.
The most common sizes are 1/4" UNF, 5/16" UNF and 3/8" UNF. There are also some UNC bolts & screws in those sizes as well.
