Silicone Hoses
11 replies to this topic
#1 tractor
tractor
  • 662 posts
Posted 14 September 2012 - 07:09 PM
Sorry for all the questions of late but I’m having a real push at the moment to try and move the mini on loads before the cold weather sets in...
so I need to order some silicone hoses, I’ve got a MK3 and I’ve fitted a 1986 1275 A+ carburettor engine, I think these are the hoses I want from mini spares http://www.minispares.com/product/Classic/Cooling_heating/Water/Hoses_fixings/C-GRH002.aspx?070302&ReturnUrl=/search/classic/hose can someone just confirm i'm barking up the right tree here?
Also I’ve noticed there’s a few different ways of routing the hoses around the engine bay, this is the set up I want with the two hoses going through the bulk head on the passenger side because I fitted a brake servo.
Attached File  029.jpg   78.23K   115 downloads
(pic taken from engine bay styling thread)
Will the above set be alright for this? or is there not different hose sets for different ways of routing them?
It’s just a lot of money and i don't want to order the wrong set so would apprieciate a few of you just confirming I'm on the right tracks
Trac
P.S I would just ring minispares but they're closed O_O
Edited by tractor, 14 September 2012 - 07:11 PM.
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 14 September 2012 - 08:00 PM
I still have no idea why people use silicone hoses, the price is staggering.
Also I got no info, so have a wee bump.
#3 tractor
tractor
  • 662 posts
Posted 14 September 2012 - 09:00 PM
It's the looks I’m afraid Adam, yes they might last a little longer and can stand higher temps and pressures but if I’m honest they just look the business in my opinion.
Granted they are expensive tho...
Anyone got any idea, will the set in the link I’ve posted above allow me to plumb my 1275 A+ carburettor engine the way it's been done in the picture above?
Trac
#4 Big_Adam
Big_Adam
  • 7,435 posts
Posted 14 September 2012 - 11:01 PM
Looks? LOOK! Engine should be covered in oil, blood, spit and 1 can of Dr. Pepper crushed up the back because you forgot to take it out.
I'm going to bed now.
#5 jaydee
jaydee
  • 8,565 posts
Posted 14 September 2012 - 11:05 PM
There easier to fit.
For what they cost, i'd rather fight to fit a rad bottom hose.
Plus i dont get the coloured pipes thing >_<
#6 tractor
tractor
  • 662 posts
Posted 15 September 2012 - 09:08 AM
so anyone know will they fit?
just looked on mini spares and can't find a standard set of hoses, just wanted to comapre the price
cheers
Trac
#7 Big_Adam
Big_Adam
  • 7,435 posts
Posted 15 September 2012 - 10:23 AM
Well, the heater hose is just half inch (sort of, later models use larger pipe size, but if you swear, you can shove a half inch pipe on).
So what you can do, just buy a silicone top and bottom hose, then by length buy the heater pipe. Its fairly standard 13mm stuff, so just measure your fitting sizes and find a pipe to suit, then plonk the ID (internal diameter for the pipe) into google with the words silicon pipe and see what you find.
~For example, 1 meter of 13mm ID pipe (half inch, close enough) - http://www.specialis...-hose-blue.html
#8 tractor
tractor
  • 662 posts
Posted 15 September 2012 - 10:58 AM
Well if I do something like that it works out about a tenner cheaper but i worry about the colour matching....
Looks like they're out of stock on mini spares anyway so might have to just get the top and bottom hoses (which are in stock and just get a length of 1/2" hose form somewhere else.
I've just rang minispares and it turns out that kit will fit what 'm trying to do and it doesn't matter how the pipes are routed, you just need a top and bottom hose and two lengths of 1/2" hose like you said above Adam, the only thing is tho they couldn't tell me when the bits are likely to back in stock, I gotta ring back Monday.
Thank for your help guys
Trac
#9 JMini
JMini
  • 86 posts
Posted 15 September 2012 - 04:14 PM
Can't believe this post! My exact problem. Gettin new hose kit from MS, but is an SPI car with 1275 A+ carb engine, and was worrying if the heater pipes would be long enough, as the current pipes come through bulkhead same as pic above.
Let me know how u get on tractor!
#10 tractor
tractor
  • 662 posts
Posted 15 September 2012 - 07:28 PM
I guess thats whats this forum is for JMini, O_O
I'm 90% sure they'll fit but i'll let know when ever they're back in stock and i get hold of a set.
so what have you done Jmini? you taken your spi engine out and replaced it with a 1275 A+ carb engine? whats the reasoning behind that then other than 1275 A+ carb engines rule..!! ;D
cheers
trac
#11 JMini
JMini
  • 86 posts
Posted 15 September 2012 - 08:32 PM
The original car was an SPI import from Germany. Done a load of miles. It was converted to RHD and the engine was replaced with an MG Metro engine with under 15k on the clock. If you believe the clocks that is....
#12 mattbeddow
mattbeddow
  • 337 posts
Posted 16 September 2012 - 11:04 AM
I replaced mine with standard kevlar hoses and it cost something like £40, just as a comparison to the silicone hoses.
As for the worrying about heater hoses length, im 99% sure you get 1 long length you cut to size that gives 1-2 ft spare at the end, depending on how you route the pipes (thats how my kevlar hoses came anyway)
