Turbo Race Spec Engine And Gearbox + All Ancillaries.
5 replies to this topic
#1 Lukie-J
Lukie-J
  • 858 posts
  • Local Club: South Devon Mini Club
Posted 15 September 2012 - 07:22 PM
MINI MG TURBO ENGINE COMPLETE.
AS YOU ALL KNOW THESE MG TURBO ENGINES ARE VERY HARD TO FIND YOU MOSTLY FIND A FEW PARTS HERE AND THERE BUT IT’S ALWAYS A PAIN GETTING THE REST OF THE PARTS YOU NEED.
SO HERE IT IS A COMPLETE HIGHLY MODIFIED MG METRO TURBO ENGINE GEARBOX AND ALL THE BITS YOU NEED.
ITS VERY HIGH SPEC AND UNBELIVBLY FAST.
(IN THE REGION OF 100- 130 BHP DEPENDING ON BOOST YOU RUN).
GENUINE MG METRO TURBO ENGINE RACE SPEC
11 STUD PHASE 4 AVONBAR TURBO BIG VALVE RACE HEAD.
ALL NICELY PORTED AND POLISHED SODIUM VALVES ECT
RECENTLY OVERHAULED (VALVES, SEALS ECT)
1.7 ROLLER ROCKERS (COST £240)
NEW CARB WITH AVONBAR NEEDLE & JETS.(COST £280)
TURBO BLOCK WITH 11cc PISTONS ON STD SIZE I THINK.
BALANCED TURBO CRANK. (STRAPED)
GARRET TURBO MODIFIED PLENUM ALL HARD PIPED TO INTERCOOLER
BAILEY DUMP VALVE (RUNNS AJUSTABLE BOOST IN CAR 7- 18 BAR)
OIL COOLER, INTERCOOLER, RAD.
EXHAUST LINK PIPE, RADIATOR, INCLUDED BUT NOT PICTURED.
AS YOU SEE IN PICTURES IT HAS ALL THE BITS YOU NEED ALTERNATOR, ELEC MG DISTRIBUTOR,
STARTER MOTOR, MANIFOLDS, CARB, TURBO, ALL LINK PIPES, BRACKETS, RODS, BOLTS, PLUGS, LEEDS, COIL,
I HAVE THE CAR(MINI CLUBMAN) THE ENGINE WAS REMOVED FROM SO ANY OTHERE BITS YOU MAY NEED GIVE ME A CALL.
(ENGINE BUYER ONLY)
THE ENGINE WAS REMOVED FOR HEAD REFURB SO WILL NEED HEAD RETORQUING.
ENGINE WAS RUNNING BUT A BIT SMOKEY ON START UP, BORES WERE A BIT GLAZED BUT LITTLE OR NO WEAR SO MAY NEED SOME WORK. (GLAZE BUST NEW RINGS ECT)
£1500ono
Would consider PX for a good 1275 engine
More pictures available on request
#2 wolfie
wolfie
  • 1,149 posts
Posted 16 September 2012 - 03:03 PM
There is alot of errors in your ad
7-18 Bar?
Also whats race spec? there must be more to it than a head and centre strap? whats the cam? what crank and rods are in there? what bearings? whats the spec of the T3? ect ect
#3 mini-power.co.uk
mini-power.co.uk
  • 43 posts
Posted 16 September 2012 - 06:48 PM
Hi is the price right because it's nearer to 500 than 1500
#4 Lukie-J
Lukie-J
  • 858 posts
Posted 20 September 2012 - 05:02 PM
Advertised on behalf of my Dad, I have no clue about turbo engines. The spec list is from the person who built the engine.
I think £500 is a bit silly really, standard 1275s are around that price.
I would assume 7-18bar is the range of adjustment?
Not really sure how to determine the crank, rods, bearings or cam without stripping the engine completely.
If you're interested then call direct: Tony - 07740 829 469.
Or I can do my best to answer any questions.
#5 Ethel
  • 26,093 posts
Posted 20 September 2012 - 05:10 PM
7-18 is more likely to be psi if we're talking about boost. 1bar= 14.7psi
#6 Lukie-J
Lukie-J
  • 858 posts
Posted 21 September 2012 - 02:41 AM
Thanks. Probably just misread the sheet.
Just because I'm not familiar with it, doesn't mean I can't sell it.
Sorry about the error.
